  • B&C ME45 1" Exponential Horn 90x40 2-Bolt
B&C SpeakersPart # 294-622
Model: ME45
The B&C Speakers ME45 1" exponential cast aluminum horn features very good loading down to 1 kHz and smooth frequency response.
  • 90&#176H x 40&#176V nominal dispersion
  • Exponential pattern
  • Durable cast aluminum construction
  • Smooth, low coloration sonic character
Your Price: $77.28
Save $51.52 (40%)
We'll send you an email when B&C ME45 1" Exponential Horn 90x40 2-Bolt is back in stock or available for preorder.
Order in the next 11 hr 10 min to ship today. Details
B&C's ME45 1" horn is constructed of durable cast aluminum, and follows carefully determined design geometries to achieve optimum driver loading and smooth on-axis response. Its classic 90 x 40 dispersion pattern makes it perfect for a variety of demanding pro audio and recording studio applications.
Specifications: • Nominal dispersion: 90°H x 40°V • Minimum frequency: 1,000 Hz • Throat diameter: 1" • Dimensions: 5.6"H x 12.2"W x 4.9"D • Cutout dimensions: 4.3"H x 10.2"W • Mounting type: Standard 2 bolt.
B&C Speakers produces a series of horns for compression drivers ranging from constant directivity models, known for their great consistency in angular coverage, to exponential models, which optimize acoustical loading and sound energy transfer. Standardized driver mounting flanges give the designer the freedom to choose the best horn/driver combination for each project.
All horns are made of cast aluminum, resulting in a robust structure that is free from resonances. The only exception to this method is the ME10; a new design that is made from precision molded plastic and incorporates stiffeners that add to its structural integrity. B&C combines advanced design techniques with critical listening tests to manufacture horns that exhibit precise pattern control, excellent driver loading, and low distortion and coloration.
BrandB&C Speakers
ModelME45
Part Number294-622
UPC844632001888
Weight2.6
ConstructionAluminum
Entry / Throat Diameter1"
Mounting Type2-Bolt
