  • B&C FB464-16 2-Way 3,500 Hz Passive Crossover For DCX464-16 Coaxial Compression Driver
B&C SpeakersPart # 294-6063
Model: FB464-16
The FB464-16 2-way passive crossover from B&C Speakers is designed to make it easy to get the optimum performance from the DCX464-16 coaxial compression driver. With a 3,500 Hz crossover frequency and built-in protection to keep the safe driver from excessive power, this crossover will make sure your DCX464-16 delivers premium audio performance and reliability.
  • Optimized to make the DCX464-16 deliver excellent performance and reliability
  • 18 dB low pass and 12 dB high pass for smooth transition between the diaphragms
  • Easy installation and hookup thanks to the built in solderless disconnects
  • Integrated over power protection lamps included in the high pass section to withstand peaks
Your Price: $138.42
MSRP: $230.70
Save $92.28 (40%)
We'll send you an email when B&C FB464-16 2-Way 3,500 Hz Passive Crossover For DCX464-16 Coaxial Compression Driver is back in stock or available for preorder.
Order in the next 2 hr 46 min to ship today. Details
B&C Speakers designed the FB464-16 2-way 3,500 Hz passive crossover specifically to allow the DXC464-16 coaxial compression driver to provide optimum performance and unmatched reliability. With included 1/4" solderless disconnects, installation and hookup are extremely simple and straight forward. The 18 dB low pass and 12 dB high pass allows a smooth and seamless transition and produces natural response through critical 3,500 Hz crossover point. In addition, the high pass section includes over power protection lamps to safeguard the high frequency diaphragm from damaging transient peaks and excessive power.
Specifications: • Power handling: 250 watts RMS, 500 watts program power • Crossover points: 3,500 Hz (18 db/octave low pass, 12 dB/octave high pass) • Dimensions: 3.94" x 4.33" • Weight: 0.8 lbs.
BrandB&C Speakers
ModelFB464-16
Part Number294-6063
UPC848864066912
Weight0.9
Crossover Type2-Way
