  • B&C ME464 1.4" Constant Directivity Horn 80 x 60 4-Bolt
B&C SpeakersPart # 294-6184
Model: ME464
B&C Speakers designed the impressive ME464 constant directivity horn to allow their coaxial ring radiator compression driver to work to their full capabilities. This large 22" x 20" polyurethane horn will load 1.4" exit compression drivers down to 300 Hz while delivering an 80° H x 60° V coverage pattern. With a standard 4-bolt mount this horn is compatible with many popular wide bandwidth compression drivers.
  • Loads 1.4" for controlled dispersion all the way down to 300 Hz
  • 80 x 60 degree dispersion pattern with excellent directivity control
  • Rigid reinforced polyurethane construction provides a solid support for large drivers
  • Perfect for building high output 2-way designs with remarkably even dispersion
  • FEM optimized flare with extremely even coverage
Your Price: $780.48
Save $520.32 (40%)
We'll send you an email when B&C ME464 1.4" Constant Directivity Horn 80 x 60 4-Bolt is back in stock or available for preorder.
One of the largest commercially available horns for professional audio, the ME464 constant directivity horn, from B&C Speakers, makes it easy to extract optimum performance from any wide bandwidth 1.4" compression driver. With a 22" x 20" mouth, this remarkable constant directivity horn is capable of loading drivers down to 300 Hz to deliver unbelievably with bandwidth. Thanks to FEM optimization, the ME464 provides a remarkably even 80° x 60° dispersion pattern for predictable response and minimal unwanted reflections creating incredible sound quality and clarity to a controlled area. Weather used in fixed high output arrays or used in high efficiency 2 and 3-way home systems, the ME464 horn is ideal for building incredibly dynamic systems that deliver unbelievable fidelity.
B&C Speakers designed the ME464 horn to support the full frequency response of their popular DCX464 ring radiator coaxial drivers. However, with a 1.4" throat and standard 4-bolt mount, this horn is compatible with many popular wide bandwidth compression drivers.
Specifications: • Throat diameter: 1.4" • Driver mounting: 4-bolt • Nominal coverage: 80°H x 60° V • Cutoff frequency: 300 Hz • Dimensions: 19.88" H x 22.64" W x 18.11" D • Cutout dimensions: 18.5" H x 21.18" W • Net weight: 10.58 lbs.
BrandB&C Speakers
ModelME464
Part Number294-6184
UPC848864066622
Weight14.25
ConstructionStructural Polyurethane
Entry / Throat Diameter1.4"
Mounting Type4-Bolt
