  • B&C DE610-8 1.4" Titanium Horn Driver 8 Ohm 4-Bolt
B&C SpeakersPart # 294-609
Model: DE610-8
B&C's DE610-8 1.4" driver utilizes a durable titanium diaphragm, 2.5" voice coil, and FEA-optimized ceramic ferrite magnet to achieve pro-level performance at a surprisingly affordable price.
  • 160 watt continuous program power capacity
  • 2.5" aluminum voice coil
  • Titanium diaphragm
  • Copper shorting cap for extended HF response
  • 108 dB sensitivity
  • 1.4" bolt-on format (4-bolt)
Your Price: $229.08
MSRP: $381.80
Save $152.72 (40%)
Only 1 In Stock
We'll send you an email when B&C DE610-8 1.4" Titanium Horn Driver 8 Ohm 4-Bolt is back in stock or available for preorder.
Order in the next 10 hr 12 min to ship today. Details
The B&C Speakers DE610-8 1.4" titanium HF driver provides accurate, extended response. Its optimized magnetic structure includes a copper cap on the pole piece, which reduces inductive losses and extends high frequency response.
Specifications: • Power handling: 80 watts RMS/160 watts program above recommended crossover of 1.2 kHz/12 dB slope • VCdia: 2.5" • Impedance: 8 ohms • Frequency response: 1,000-18,000 Hz • SPL: 108 dB 1W/1m • Dimensions: 6.1" diameter x 2.5" depth • Net weight: 8.4 lb. • Replacement diaphragm available.
B&C Speakers' line of compression drivers is the result of a continuous research effort, dedicated to refine every component in the structure, and their overall balance. Diaphragms are made of titanium, mylar, or polyimide, in order to get the required results in efficiency and bandwidth. Their shape and structure is mathematically evaluated well before building the first prototype. Afterwards, their performance is tested with methods that range from modal analysis to laser vibrotomy.
All voice coils are of the edgewound ribbon type, and made of aluminum to reduce mass and achieve the best electro-acoustic performance. The magnet assembly is designed and optimized with up-to-date software for Finite Element Analysis (FEA) and complemented, where needed, by a copper cap to improve frequency extension and linearity. Equal care is taken in the design of phase plugs, whose role in enhancing performance and reducing distortion artifacts is critical for compression drivers. The precision and transparency of B&C compression drivers is constantly improved by the progress in acoustical modeling and simulation.
BrandB&C Speakers
ModelDE610-8
Part Number294-609
UPC844632001796
Weight9.2
Diaphragm MaterialTitanium
Exit Diameter1.4"
Mounting Type4-Bolt
Power Handling (RMS)160 Watts
