  • B&C DE550TN 1" Neodymium Compression Driver
B&C SpeakersPart # 294-5848
Model: DE550TN
The B&C Speakers DE550TN offers dynamic, articulate sound reproduction, thanks to great engineering and the use of sophisticated technologies and materials. With a powerful neodymium motor and high power handling the DE550TN is perfect for the highest output systems.
  • Neodymium motor cuts weight without sacrificing anything
  • 140W continuous program power capacity
  • 1" throat with 2-bolt mount for use with many popular horns
  • Recommended for use with 12 dB crossover at 1,200 Hz
Your Price: $251.04
MSRP: $418.40
Save $167.36 (40%)
Only 2 In Stock
We'll send you an email when B&C DE550TN 1" Neodymium Compression Driver is back in stock or available for preorder.
Order in the next 5 hr 0 min to ship today. Details
B&C's DE550TN 1" high frequency compression driver features detail and accurate response. Its 2" high temperature titanium diaphragm and lightweight but powerful neodymium magnet assembly allow high sensitivity and low distortion up to 17 kHz. Popular with professional users as well as many discriminating "high efficiency" home audio enthusiasts, the B&C Speakers DE550TN is one of the most high fidelity compact 1" compression drivers available.
Specifications: • Power handling: 70 watts RMS/140 watts program above recommended crossover of 1.2 kHz/12 dB slope • VCdia: 2" • Impedance: 8 ohms • Frequency response: 1,000-17,000 Hz • SPL: 108 dB 1W/1m • Dimensions: 3.62" diameter x 1.93" depth • Net weight: 3.75 lb.
BrandB&C Speakers
ModelDE550TN
Part Number294-5848
UPC848864033051
Weight3
Diaphragm MaterialTitanium
Exit Diameter1"
Mounting Type2-Bolt
Power Handling (RMS)140 Watts
