  • B&C DE550 1" Polymer Dome Neodymium Compression Driver 8 Ohm 2-Bolt
B&C SpeakersPart # 294-5847
Model: DE550
2 Questions, 2 Answers or
The B&C Speakers DE550 offers dynamic, articulate sound reproduction, thanks to great engineering and the use of sophisticated technologies and materials. With a powerful neodymium motor and high power handling the DE550 is perfect for the highest output systems.
  • Neodymium motor cuts weight without sacrificing anything
  • 140W continuous program power capacity
  • 1" throat with 2-bolt mount for use with many popular horns
  • Recommended for use with 12 dB crossover at 1,200 Hz
Your Price: $212.10
MSRP: $353.50
Save $141.40 (40%)
We'll send you an email when B&C DE550 1" Polymer Dome Neodymium Compression Driver 8 Ohm 2-Bolt is back in stock or available for preorder.
Estimated back in stock 1/2/2026
B&C's DE550 1" high frequency compression driver features smooth and accurate response. Its 2" high temperature polymer diaphragm and lightweight but powerful neodymium magnet assembly allow high sensitivity and low distortion up to 17 kHz. Popular with professional users as well as many discriminating "high efficiency" home audio enthusiasts, the B&C Speakers DE550 is one of the most high fidelity compact 1" compression drivers available.
Specifications: • Power handling: 70 watts RMS/140 watts program above recommended crossover of 1.2 kHz/12 dB slope • VCdia: 2" • Impedance: 8 ohms • Frequency response: 1,000-17,000 Hz • SPL: 108 dB 1W/1m • Dimensions: 3.62" diameter x 1.93" depth • Net weight: 3.75 lb. • Replacement diaphragm: 294-6319.
BrandB&C Speakers
ModelDE550
Part Number294-5847
UPC848864034805
Weight2.65
Diaphragm MaterialPoly / Mylar
Exit Diameter1"
Mounting Type2-Bolt
Power Handling (RMS)140 Watts
