B&C DE360-16 1" Polymer Compression 16 Ohm 2/3-Bolt
The B&C Speakers DE360-16 1" ring radiator HF compression driver utilizes a ketone polymer diaphragm and an FEA optimized neodymium motor. The DE360-16 allows for a wide range of applications, including compact two-way boxes and line arrays.
- Ketone polymer diaphragm for smooth and natural response
- Recommended crossover of 1,800 Hz or higher with 12 dB slope
- 16 ohm impedance is ideal for use in multi driver systems and stackable line arrays
- Ring radiator design to prevent dome breakup
- Extensive FEA modeling and physical testing has led to incredible efficiency
See all items in Horn Drivers Your Price: $117.36
MSRP: $195.60
Only 2 In Stock
We'll send you an email when B&C DE360-16 1" Polymer Compression 16 Ohm 2/3-Bolt is back in stock or available for preorder.
