NEW B&C 15DS100 DS Series 15" High Energy Neodymium Subwoofer 8 Ohm
This advanced subwoofer design incorporates a newly developed, longer four-layer aluminum voice coil. This design improves heat dissipation, increases magnetic gap energy, raises sensitivity, boosts power handling, reduces distortion, and enhances overall performance. The 15DS100 uses a 37 mm long, 4" (100 mm) diameter copper clad aluminum wire voice coil, delivers a 1500 watt AES power rating, achieves 96.8 dB sensitivity, and offers more than 14.0 mm of Xvar, representing a major advancement over comparable models in the B&C lineup.
- Excursion-optimized lead wires woven through spider for minimal motion interference
- Double silicone spider with optimized compliance for stable excursion and control
- Ventilated voice coil gap to reduce power compression under heavy use
- Aluminum demodulating ring for very low distortion
NEW $563.04
MSRP: $938.40
We'll send you an email when B&C 15DS100 DS Series 15" High Energy Neodymium Subwoofer 8 Ohm is back in stock or available for preorder.
Estimated back in stock 5/8/2026
