B&C 14CXN88 13.5" Professional Neodymium Coaxial Speaker 80 x 80 Degree 4/8 Ohm
The powerful motor and large voice coils give the B&C Speakers 14CXN88-4 14" coaxial full range speaker more output capability and lower distortion than most high output coaxial speakers on the market. When space is a concern, this driver is perfect for providing high fidelity and maximum output capability.
- Coaxial design combines the LF transducer and 3" compression driver for more compact point-source system layouts
- Neodymium magnet structure reduces weight while supporting high-output professional use
- 3" compression driver with a polyimide diaphragm supports extended high-frequency reproduction
- 80° nominal coverage helps maintain more controlled dispersion in installed or portable systems
- 700 W continuous program power handling supports demanding sound reinforcement use
- 98 dB sensitivity helps deliver strong output from available amplifier power
- Frequency response from 50 Hz to 20 kHz covers a wide operating range from one driver
Your Price: $815.88
MSRP: $1,359.80
Only 2 In Stock
We'll send you an email when B&C 14CXN88 13.5" Professional Neodymium Coaxial Speaker 80 x 80 Degree 4/8 Ohm is back in stock or available for preorder.
