  • B&C 12CLX64 12" Professional Coaxial Speaker 60 x 60 Degree 8 Ohm
B&C SpeakersPart # 294-5949
Model: 12CLX64
The B&C 12CLX64 12" Professional Coaxial Speaker is designed to deliver powerful, full-range sound in a compact, integrated design. Featuring a combination of a 12" woofer and a high-frequency driver, this coaxial speaker ensures seamless audio performance for demanding professional applications, offering clarity and depth across all frequencies.
  • A frequncy response of 54 Hz to 18 kHz offers impactful low-end and clear high-end performance
  • Coaxial design ensures a smooth, cohesive sound with minimal phase interference
  • A single neodymium magnet assembly keeps everything cohesive and cuts down on weight
  • The aluminum demodulating ring means very low distortion
  • 500 watts of continuous power offer the ability to be heard over the roar of the crowd
  • Durable materials provide reliability for the abuse of a professional environment
  • Made to work perfectly with the FBCLX64 (Part # 294-5781)
Your Price: $386.46
MSRP: $644.10
Save $257.64 (40%)
We'll send you an email when B&C 12CLX64 12" Professional Coaxial Speaker 60 x 60 Degree 8 Ohm is back in stock or available for preorder.
Order in the next 11 hr 42 min to ship today. Details
The B&C 12CLX64 12" Professional Coaxial Speaker offers high-performance audio in a robust, space-efficient design, ideal for both portable and installed sound systems. With its integrated coaxial configuration, the speaker combines a 12" woofer for deep, powerful bass and a high-frequency driver for crisp, detailed highs, creating a seamless full-range sound. The coaxial design minimizes phase interference, delivering consistent, coherent audio output across all frequencies, perfect for professional applications requiring clarity and precision.
Engineered for high efficiency, the 12CLX64 has an aluminum demodulating ring to ensure minimal distortion, allowing it to perform exceptionally well even at higher volumes. This makes it a suitable choice for environments such as concert venues, theaters, and large event spaces, where loud, clear sound is essential. The speaker's high-quality construction materials ensure reliability and durability, allowing it to withstand the demands of continuous use in professional settings.
Thanks to its compact design, the B&C 12CLX64 is easy to integrate into various sound systems without sacrificing performance. Whether it’s being used in portable PA systems, stage monitors, or fixed installations, this speaker delivers powerful, accurate sound across nearly the entire frequency spectrum. For audio professionals looking for a versatile, high-performance speaker, the 12CLX64 provides the perfect combination of deep bass, clear highs, and reliable, long-term operation.
General Specifications
  • Nominal Diameter: 320 mm (12in)
  • Frequency Range: 54 Hz - 18,000 Hz
  • Nominal Impedance: 8 Ohms
  • Dispersion Angle: 60°
  • Sensitivity: 96 dB
Specifications (LF unit)
  • Continuous Power Handling: 500W
  • Winding Material: Copper
  • Nominal Diameter: 320 mm (12 in)
  • Minimum Impedance: 6.6 Ohms
  • Winding Depth: 14.5 mm (0.57 in)
  • Woofer Cone Treatment: WP Waterproof Front Side
  • Nominal Power Handling: 250W
  • Voice Coil Diameter: 64 mm (2.5 in)
  • Flux Density: 0.9 T
  • Former Material: Kapton
  • Magnetic Gap Depth: 8 mm (0.31 in)
Specifications (HF unit)
  • Sensitivity: 106 dB
  • Continuous Power Handling: 140 W
  • Winding Material: Aluminum
  • Nominal Diameter 320 mm (12 in)
  • Minimum Impedance: 7.8 Ohms
  • Inductance: 0.14 mH
  • Nominal Power Handling: 70W
  • Voicer Coil Diameter: 51mm (2 in)
  • Flux Density: 1.6 T
  • Recommended Crossover: 1.2 kHz
  • Diaphragm Material: HT Polymer
BrandB&C Speakers
Model12CLX64
Part Number294-5949
Weight7.05
Nominal Diameter12"
Power Handling (RMS)500 Watts
Frequency Response54 to 18,000Hz
Sensitivity96dB 2.83V/1m
Voice Coil Diameter2.5"
Resonant Frequency (Fs)54Hz
DC Resistance (Re)5.6Ω
Voice Coil Inductance (Le)0.54mH
Mechanical Q (Qms)10.1
Electromagnetic Q (Qes)0.61
Total Q (Qts)0.57
Compliance Equivalent Volume (Vas)2.61ft³
BL Product (BL)11.86T·m
Diaphragm Mass Inc. Airload (Mms)45.3g
Maximum Linear Excursion (Xmax)5.5mm
Surface Area of Cone (Sd)522cm²
Magnet MaterialNeodymium
Overall Outside Diameter12.32"
Baffle Cutout Diameter11.1"
Depth6.46"
Sealed Volume1.981ft³
Sealed F380.3Hz
Vented Volume5.304ft³
Vented F338.85Hz
