The B&C FBCLX64 2-Way 1,700 Hz Passive Crossover is engineered to deliver precise frequency division between drivers, ensuring smooth and balanced audio performance across a wide range of applications. By splitting the audio signal at 1,700 Hz, this crossover ensures that the woofer and tweeter work together seamlessly, minimizing phase issues and creating a cohesive sound profile that enhances clarity and detail.
Whether used in concert venues, theaters, or large PA systems, this crossover helps to maintain clean, distortion-free sound even at high volumes. Its passive design also makes installation simple, as it requires no external power source, offering convenience for both new builds and retrofits.
Built for durability, the FBCLX64 features high-quality components that can withstand the rigors of continuous use in professional environments. Its compact form factor allows for easy integration into a variety of speaker enclosures without sacrificing performance, making it a versatile choice for audio engineers and system designers seeking reliable, high-quality crossover solutions.
- Nominal Impedance: 8 Ohms
- Filter Type: Two Way
- Overall Dimensions: 173x120 mm (6.81x4.72 in)
- Crossover Frequency: 1.7 kHz
- Slope: 24 - 12 dB/oct
- Net Weight: 0.64 kg (1.41 lbs)
