  • Audtek VC-100R Impedance Matching Rotary Speaker Volume Control 100W
CLEARANCE Audtek VC-100R Impedance Matching Rotary Speaker Volume Control 100W
Audtek ElectronicsPart # 300-566
Model: VC-100R
The Audtek VC-100R Impedance Matching Rotary 100W Volume Control gives you 12 indented attenuation steps for use with any combination of 4, 8, or 16-ohm speakers. Independent grounds allow you to use the volume control with any amplifier.
  • 12 indented attenuation steps from no signal to full signal with no signal quality loss
  • Impedance matching design for use with any combination of 4, 8, or 16-ohm speakers
  • Fits into most deep single gang electrical junction boxes
  • Independent grounds allow you to use with any amplifier
  • Includes matching white wall plate
We'll send you an email when Audtek VC-100R Impedance Matching Rotary Speaker Volume Control 100W is back in stock or available for preorder.
The Audtek VC-100R Impedance Matching Rotary 100W Volume Control gives you 12 indented attenuation steps for use with any combination of 4, 8, or 16-ohm speakers. Impedance matching design allows you to use the control with any combination of 4, 8, or 16-ohm speakers. Easily adjust impedance by adjusting the position of two shorting bars. High-quality components ensure no signal quality loss while attenuating. A broad frequency response retains a tight low-end response and crisp highs. Phoenix-type connectors accept up to 14 AWG to simplify the installation process.
Type: Rotary impedance matching
Power handling: 2 x 100W
Speaker impedance: 4, 8, 16 ohms
Attenuation steps: 12 (step 1 is no signal, steps 2-7 at 3 dB each, step 8-11 at 6 dB each, step 12 is full signal)
Frequency response: 35-20,000 Hz
Input / output connections: Phoenix-type, up to 14-gauge speaker cable
Size: Standard single gang
Dimensions: 4" x 1-3/4" x 3"
BrandAudtek Electronics
ModelVC-100R
Part Number300-566
UPC848864063805
Weight1.25
Control SurfaceRotary Knob
Wall Plate ColorWhite
