  • Audtek 6 ft. 3.5mm Stereo Male to Female Extension Audio Cable Dual Shielded with Braided Jacket
CLEARANCE Audtek 6 ft. 3.5mm Stereo Male to Female Extension Audio Cable Dual Shielded with Braided Jacket
Audtek ElectronicsPart # 181-933
Model: 35BMFC-6
These slim plug cables follow the same physically smaller design trend as your equipment, making sure that they're visually unobtrusive and fit better with more protective cases than traditional 3.5 mm ever have! The nylon weave protects the rubber jacket plus adds a more professional look.
  • Slim 8 mm outer shell fits into smartphones and other audio devices without removing their protective case
  • Foil and braid shield combines with metal shell for maximum interference protection
  • Nylon weave protects the outer jacket from being cut by metal, plastic, and wooden shelves
  • Add a professional look to exposed cables connected to home or portable music devices
  • Gold plated plug for better signal transfer
CLEARANCE $1.40
Save $7.59 (84%)
228 In Stock
We'll send you an email when Audtek 6 ft. 3.5mm Stereo Male to Female Extension Audio Cable Dual Shielded with Braided Jacket is back in stock or available for preorder.
Order in the next 3 hr 55 min to ship today. Details
With audio electronics getting smaller all the time, the Audtek Electronics 3.5 mm stereo cable is a common way to connect audio sources such as smart phones, computers, cell phones, and audio equipment to amplified speakers, home stereo equipment, or portable DJ systems. Sometimes, an integrated 3.5 mm cable just is not quite long enough. For those instances, this extension cable comes in handy.
This slim plug 3.5 mm stereo cable fits more than just the visual aesthetic of today's electronics. The slim metal plug with integrated strain relief works with many protective cases that you'd have to remove for use with a traditionally-sized plug, easing frustration and saving wear and tear. The foil and braid shield combines with metal shell for maximum interference protection that might hinder your musical experience.
The nylon weave makes the cable more durable and gives any audio hookup a more professional look. Durability is the key for temporary audio hookups. Cables get walked on or dragged across metal racks that damage the rubber jack sometimes down to the inner conductors. Cables getting shorts in them is the worse thing that happens right before a show starts. Tears in jackets also make your audio setup look unprofessional and that'll never happen with Audtek 3.5 mm nylon weave cables.
BrandAudtek Electronics
Model35BMFC-6
Part Number181-933
UPC848864072265
Weight0.15
Cable Length6feet
Cable Type3.5 mm Male to Female
