  • Audio-Technica AT-VM95C Dual Moving Magnet Cartridge 0.6 mil
Audio-TechnicaPart # 240-5621
Model: AT-VM95C
The Audio-Technica VM95C dual moving magnet cartridge delivers a powerful 4 mV output with excellent channel separation and low distortion. The durable, low-resonance housing includes threaded inserts that enable the cartridge to be mounted to the headshell with just two screws with no nuts required.
  • VM95 Series dual magnet cartridge with 0.6 mil conical stylus
  • Aluminum cantilever
  • Specially wound coils increase output voltage
  • Durable low-resonance polymer housing
  • Threaded inserts in cartridge body enable cartridge to be mounted to headshell with just two screws with no nuts required
  • Compatible with any AT-VMN95 replacement stylus
Your Price: $54.00
We'll send you an email when Audio-Technica AT-VM95C Dual Moving Magnet Cartridge 0.6 mil is back in stock or available for preorder.
Order in the next 6 hr 37 min to ship today. Details
This VM95 Series cartridge with 0.6 mil conical stylus fits half-inch mount turntables. The cartridge’s special coil design delivers a powerful output level of 4.0 mV. It also offers excellent channel separation and low distortion for outstanding tonal quality. The durable, low-resonance housing includes threaded inserts that enable the cartridge to be mounted to the headshell with just two screws – no nuts required. And since all VM95 Series share the same body, the stylus can be replaced with any of the six interchangeable AT-VMN95 replacement styli.
Frequency response: 20-20,000 Hz
Channel separation: 18 (dB at 1 kHz)
Vertical tracking angle: 23°
Vertical tracking force: 1.8-2.2 g (2.0 g standard)
Stylus construction: Bonded round shank
Recommended load impedance: 47,000 ohms
Coil impedance: 3.3 k ohms (1 kHz)
DC resistance: 485 ohms
Coil inductance: 550 mH (1 kHz)
Load capacitance: 100 to 200 pF
Output: 4.0 mV (1 kHz, 5 cm/sec.)
Channel balance: 2.5 dB (1 kHz)
Stylus shape: 0.6 mil conical
Cantilever: Aluminum pipe
Mount: Half-inch
Replacement stylus: AT-VMN95C
Accessories included: Two 11 mm installation screws, two 8 mm installation screws, two washers
Dimensions: 17.2 mm (0.68") H × 18.9 mm (0.74") W × 28.3 mm (1.20") D
Weight: 6.1 g (0.22 oz)
BrandAudio-Technica
ModelAT-VM95C
Part Number240-5621
