  • Audio-Technica AT-HS6BK Universal 1/2" Mount Headshell for 4-pin Turntable Cartridges - Black
Audio-TechnicaPart # 240-5547
Model: AT-HS6BK
The Audio-Technica AT-HS6 Universal 1/2"-Mount Headshell is compatible with 4-pin turntable cartridges. It features an ultra-lightweight (9 g) aluminum die-cast body to keep vibration to a minimum and a finger lift to enable precise stylus placement. The headshell is also equipped with gold-plated lead wires for lossless signal transmission and comes with mounting screws.
  • Universal 1/2"-mount headshell for 4-pin turntable cartridges
  • Ultra-lightweight aluminum die-cast body keeps vibration to the bare minimum
  • Finger lift enables precise stylus placement
  • Gold-plated lead wires for lossless signal transmission
  • Includes mounting screws
Your Price: $39.00
We'll send you an email when Audio-Technica AT-HS6BK Universal 1/2" Mount Headshell for 4-pin Turntable Cartridges - Black is back in stock or available for preorder.
The AT-HS6 is a universal 1/2"-mount headshell for 4-pin turntable cartridges. It features an ultra-lightweight (9 g) aluminum die-cast body to keep vibration to a minimum for accurate playback both for DJs and causal listeners. A finger lift enables simple, precise stylus placement. The headshell is also equipped with gold-plated lead wires for lossless signal transmission and comes with mounting screws for connecting the headshell to a cartridge.
• Material: Aluminum
• Connector: Aluminum
• Wire leads: Gold plated
• Mount: 1/2" universal
• Pin connections: 4
• Color: Black
• Weight: 9g (with lead wires)
• Dimensions: 13mm H x 21.4mm W x 48.9mm D
BrandAudio-Technica
ModelAT-HS6BK
Part Number240-5547
UPC4961310147068
