  • Audio-Technica AT-SB727-BK Sound Burger Compact Portable Turntable Black
Audio-TechnicaPart # 240-5710
Model: AT-SB727-BK
The Audio-Technica AT-SB727, also known as the Sound Burger, is a portable Bluetooth turntable that blends nostalgic design with modern technology. Originally introduced in the 1980s, this reimagined classic is compact, lightweight, and packed with features, making it perfect for vinyl enthusiasts seeking a versatile listening experience.
  • Compact, lightweight design for easy portability
  • Bluetooth connectivity for wireless streaming to headphones or speakers
  • Built-in rechargeable battery with up to 12 hours of playback
  • Belt-drive system supporting 33-1/3 and 45 RPM records
  • Die-cast aluminum alloy platter for reduced vibrations and enhanced sound quality
  • Dynamic balance system with spring-applied stylus pressure for accurate tracking
  • Replaceable diamond stylus for long-lasting high-fidelity performance
Your Price: $199.00
We'll send you an email when Audio-Technica AT-SB727-BK Sound Burger Compact Portable Turntable Black is back in stock or available for preorder.
Sound Burger - Portable Bluetooth Turntable
The AT-SB727 brings back the retro charm of the original Sound Burger with significant modern upgrades. Its Bluetooth connectivity enables seamless wireless playback, allowing you to enjoy your records without the constraints of cables. For those who prefer traditional connections, the turntable also includes an audio cable, making it a versatile solution for a variety of setups. The built-in rechargeable battery provides up to 12 hours of continuous playback, ensuring that you can enjoy your vinyl collection all day long.
The belt-drive system is designed to accommodate both 33-1/3 and 45 RPM records, making it suitable for a wide range of vinyl records. The dynamic balance system uses spring-applied stylus pressure to ensure accurate tracking and minimal wear on your records, preserving them for years to come. The die-cast aluminum alloy platter, combined with a damping design, reduces vibrations and enhances sound quality, delivering a premium listening experience.
Compact and stylish, the AT-SB727 is a perfect blend of retro aesthetics and cutting-edge technology. Its lightweight build makes it easy to take to parties, picnics, or any gathering where great music is a must. Whether you're rediscovering your vinyl collection or diving into the world of records for the first time, the Audio-Technica Sound Burger offers exceptional performance in a timeless package.
  • Motor: DC servo motor
  • Power Supply: DC 3.6 V lithium ion battery
  • Drive Method: Belt-drive
  • Speeds: 33-1/3 RPM, 45 RPM
  • Turntable Platter: Aluminum
  • Wow and Flutter: < 0.25 % (WTD) at 3 kHz
  • Signal-to-Noise Ratio: > 50dB (DIN-B)
  • Cartridge Type: VM
  • Output Level: 150 mV nominal at 1 kHz, 5 cm/sec (No phono-output)
  • Phono Pre-Amp Gain: 36 dB nominal, RIAA equalized
  • Charging Specifications: 5 V, 0.5 A
  • Power Consumption: 1.5 W (when charging)
  • Charging Time: Approx. 12 hours*
  • Operating Time: Approx. 12 hours*
  • Input Jack: USB Type-C jack
  • Dimensions: 100 mm (3.9") × 290 mm (11") × 70 mm (2.8") (W×D×H)
  • Operating Temperature: 5°C to 40°C (41°F to 104°F)
  • Accessories Included:
    ・USB cable (1.5 m (5'), USB Type-A - USB Type-C)
    ・RCA audio cable
    ・45 RPM adapter
  • Replacement Stylus: ATN3600LC
  • Communication System: Bluetooth version 5.2
  • Frequency Band: 2.402 GHz to 2.480 GHz
  • Maximum RF Output: 10 mW EIRP
  • Maximum Communication Range: Line of sight - approx. 10 m (33')
  • Modulation Method: GFSK, Pi/4DQPSK, 8DPSK
  • Spread Spectrum Method: FHSS
  • Compatible Bluetooth Profile: A2DP, AVRCP
  • Support Codec: SBC
  • Transmission Band: 20 to 20,000 Hz
  • Notes: * The figures above depend on the operating conditions. For product improvement, the product is subject to modification without notice
BrandAudio-Technica
ModelAT-SB727-BK
Part Number240-5710
Weight2.9
Drive TypeBelt Drive
