  • AtlasIED Atmosphere AZA404 400-Watt Networkable 4-Channel Power Amplifier
AtlasIEDPart # 242-9678
Model: AZA404
The AtlasIED AZA404 is a professional 4-channel power amplifier built for commercial audio installations and integration with the Atmosphere product line. With networkable features and flexible output modes, it's designed to adapt to various speaker loads and streamline system setup.
  • Configurable for 70 V / 100 V, 8 Ω or 4 Ω speaker loads for versatile deployment
  • Web-based interface via Ethernet for remote monitoring and configuration
  • All inputs routable to any output channel, offering flexible signal distribution
  • Accessory card slot supports optional Dante® audio module for digital input expansion
  • Front-panel indicators for signal, limit/clip, and mode status to aid system diagnostics
  • Convection cooling plus variable-speed fan ensures stable operation under load
  • Rack-mount 1U form factor at 19″ wide for streamlined integration in AV racks
Your Price: $1,546.99
MSRP: $1,931.99
Save $385.00 (20%)
Out of Stock
We'll send you an email when AtlasIED Atmosphere AZA404 400-Watt Networkable 4-Channel Power Amplifier is back in stock or available for preorder.
Dropship Order Item
The AtlasIED Atmosphere AZA404 four channel amplifier is engineered to integrate seamlessly with the Atmosphere family of products, including the AZM series processors. It can be configured in channel pairs to deliver up to 100 watts per channel into a wide range of speaker loads, supporting low impedance operation at 4 or 8 ohms as well as 70V and 100V distributed audio systems.
Out of the box, the AZA404 ships in a four channel 70V configuration, ready for immediate use without the need for network setup or additional programming. This makes it an ideal, plug and play companion for AtlasIED Atmosphere signal processors, ensuring a fast, reliable, and straightforward installation experience.
Specficiations
  • Power Output: 4 x 100-Watts @ 70.7V
  • Power Output: 4 x 100-Watts @ 100V
  • Power Output: 4 x 75-Watts @ 8Ω
  • Power Output: 4 x 50-Watts @ 4Ω
  • Power Output: 2 x 100-Watts @ 70.7V, 2 x 75-Watts @ 8Ω
  • Power Output: 2 x 100-Watts @ 100V, 2 x 50-Watts @ 4Ω
  • Amplifier Topology: Class AB Switching Hybrid -BASH
  • Input Sensitivity: 750mV Balanced, 0dBU
  • Input Impedance: Balanced 40k
  • Maximum Input Signal: +14dBU Inputs 1-4, +7dBU Inputs 5-8 with Dante™
  • THD: 1% @ Rated Output
  • Frequency Response: 20Hz - 20kHz (DSP Filters Set to Flat)
  • Signal To Noise Ratio: >100dB Below Rated output (A-Weighted)
  • Crosstalk: 73dB @ 1kHz
  • Voltage: 110V - 120V & 220V - 240V Auto Switch Over, 50/60Hz
  • Rack Units: 1
  • Height: 1.75" (45mm)
  • Width: 19" (483mm)
  • Depth: 15.5" (394mm)
  • Weight: 13 lbs. (5.92kg)
Experience freedom from Complexity to create your
BrandAtlasIED
ModelAZA404
Part Number242-9678
UPC612079700721
Weight17
Power Output (RMS @ 70V)101W to 200W
Weight Range10 to 19 lbs.
