  • AtlasIED SM42T-B 4" 2-Way Speaker Pair Black
AtlasIEDPart # 242-810
Model: SM42T-B
The AtlasIED Strategy Series® II two-way, surface-mount loudspeaker systems are ideal for indoor and outdoor installation in conference rooms & classrooms, boutiques/shops, restaurants/cafes, decks/patios, recreation/sport centers, amusement/theme parks, and houses of worship.
  • Weather resistant construction for year-round indoor or outdoor use
  • UV-resistant, talc impregnated, polypropylene injection molded enclosure
  • Powder coated aluminum grill
  • Conforms to stringent 100HR salt spray test per the ASTM B117 standard
  • Color matched heavy-duty C-shaped mounting bracket is included
  • TRX WaveGuide™ high frequency director for vocal and music accuracy and clarity
  • SAE 1/4"-20 brass inserts allow easy integration of "off-the-shelf" security hardware
AtlasIED SM42T-WH 4" 2-Way Speaker Pair White
Price: $247.99Part # 242-812
See all items in Commercial Surface-Mount Speakers
Your Price: $247.99
Save $56.00 (18%)
We'll send you an email when AtlasIED SM42T-B 4" 2-Way Speaker Pair Black is back in stock or available for preorder.
The AtlasIED Strategy Series® II two-way, surface-mount loudspeaker systems are ideal for indoor and outdoor installation in conference rooms & classrooms, boutiques/shops, restaurants/cafes, decks/patios, recreation/sport centers, amusement/theme parks, and houses of worship. Includes a 70.7V/100V transformer with screwdriver adjustable tap settings from 2-16 watts for distributed sound applications and a transformer bypass setting for direct coupled 8 ohm applications.
Specifications: • Power rating: 30 watts RMS • Impedance: 8 ohms (xfmr. bypassed) • 70.7V Taps: 2, 4, 8, 16 watts • Frequency response: 110 Hz-20 kHz • Dimensions (less bracket): 7" H x 5" W x 5.94" D • Sold in pairs • Mfg. #SM42T-B.
BrandAtlasIED
ModelSM42T-B
Part Number242-810
UPC612079181070
Unit of MeasurePairs
Weight9.26
ColorBlack
Configuration2-way
Input Rating8 ohm|70V|100V
Mounting StyleSurface Mount
Woofer Diameter4"
Special FeaturesIndoor / Outdoor
