  • AtlasIED DT22 24" x 24" Drop-In Ceiling Tile Speaker Pair
CLEARANCE AtlasIED DT22 24" x 24" Drop-In Ceiling Tile Speaker Pair
AtlasIEDPart # 242-877
Model: DT22
The AtlasIED 24" x 24" Drop Tile ceiling speaker pair is ideal for quick and clean installations in new or existing drop ceilings while not sacrificing sound quality.
  • Standard 8" full-range speaker with rear enclosure for protection and enhanced sound quality
  • All in one assembled unit drops into standard 24" x 24" ceiling grids for quick and easy installation
  • Solid white panel with integrated mesh grill blends in with most ceiling tile designs
  • Built-in 4-watt 70-volt transformer for simple integration
  • UL certified, safety listed to UL1480/2403
Quam SYSTEM 12 24" x 24" Lay-In Ceiling Tile Speaker 5W-25/70V
Price: $137.36Part # 244-3136
See all items in Commercial Ceiling Speakers
We'll send you an email when AtlasIED DT22 24" x 24" Drop-In Ceiling Tile Speaker Pair is back in stock or available for preorder.
The AtlasIED DT22 is designed for clear intelligibility in a time saving package. Ideal for use in department stores, office spaces, doctors offices or anywhere large quantities of speakers are to be utilized in a drop ceiling. The high-efficiency 8" speaker effortlessly cuts through background noises for music and paging.
The 24" x 24" size allows for lightning quick installation and the simple, white design means it will blend in with the overall aesthetic of almost any drop tile ceiling. The included 25/70V 4-watt transformer allows for straight forward installation and volume balancing. The rear enclosure protects the speaker and helps increase bass response. Sold in pairs.
Specifications: • Length: 23.9• (60.7 cm) • Width: 23.9• (60.7 cm) • Depth: 4.53• (11.5 cm) • Shipping weight: 11.3 lbs (5.125 kgs) • Frequency response: 100 Hz - 5,000 Hz • Power taps: 0.25W, 0.5W, 1W, 2W and 4W • Speaker type: Standard 8" • Dispersion: 105° • Sensitivity: 96 dB 1W/1m • UL listed/standard: 1480, 2043.
BrandAtlasIED
ModelDT22
Part Number242-877
UPC612079190744
Unit of MeasurePairs
Weight18.25
Input Rating25V/70.7V
Mounting StyleDrop-in Tile
Woofer Diameter8"
Special FeaturesUL1480-UL2043
