  • AtlasIED DR-42 21" 85 degree Uniform Coverage Horn
AtlasIEDPart # 242-847
Model: DR-42
The AtlasIED DR-42 is a weather-resistant loudspeaker designed for use with a compression driver forclear voice and music reproduction in outdoor or demanding environments. Its durable construction and wide frequency range make it suitable for a variety of paging and sound reinforcement applications.
  • 85° dispersion ensures even, wide sound spread
  • Durable, all-metal IP45 weather‑resistant design for year‑round use
  • Built‑in resonance‑damping ring for extended frequency performance
  • Accepts standard 1‑3/8"‑18 threaded compression drivers, including PD and SD Series
  • Exponentially‑flared horn geometry delivers uniform sound dispersion
  • U‑type steel mounting bracket allows precise aiming in indoor/outdoor environments
  • Driver sold separately
Your Price: $216.99
MSRP: $268.99
Save $52.00 (19%)
Out of Stock
We'll send you an email when AtlasIED DR-42 21" 85 degree Uniform Coverage Horn is back in stock or available for preorder.
Special Order Item Ships in 3-7 Days
AtlasIED DR Series double re-entrant horns are built for use with compression driver units, delivering superior music and voice reproduction over long distances and through ambient noise. The circular projectors include a resonance damping ring to achieve optimal response across a wide frequency range.
These weather-resistant horns are compatible with AtlasIED PD and SD Series compression drivers, as well as any driver featuring a standard 1 3/8"-18 male thread coupling. An integral U-type steel mounting bracket allows for precise directional aiming and makes installation easy in outdoor or industrial settings.
Constructed from rugged, all-metal materials with an exponentially flared design, the horns are finished in a durable grey epoxy coating.
  • Dispersion: 85°
  • Depth: 16" (40.64 cm)
  • Diameter: 21" (53.34 cm)
  • Shipping Weight: 13.00 lbs (5.90 kgs)
BrandAtlasIED
ModelDR-42
Part Number242-847
UPC612079112333
Weight13.6
