CLEARANCE Arlington THE HOOP™ H2S 2" Cable Ring with Screw
- 1/4-20 screw included for easier mounting
- For use with MC/AC communications cable; do not exceed load rating of 25
- 2" diameter with an internal bearing surface 5/8" wide
- Can be mounted horizontally or vertically
- Compliant with EIA/TIA standards
- Listed for use in environmental air handling spaces per NEC code requirements
- UL Listed
We'll send you an email when Arlington THE HOOP™ H2S 2" Cable Ring with Screw is back in stock or available for preorder.
