  • Adire Audio ADKA18D2 18" Kali Subwoofer DVC 2x2 Ohm
CLEARANCE Adire Audio ADKA18D2 18" Kali Subwoofer DVC 2x2 Ohm
Adire AudioPart # 294-156
Model: ADKA18D2
Read 1 Review or
The Adire Audio Kali 18" is a high-performance car audio subwoofer engineered to deliver exceptional low-frequency reproduction for audio enthusiasts seeking powerful and precise bass. Utilizing Adire Audio's patented XBL² motor technology, the Kali 18" achieves remarkable linear excursion, resulting in accurate and distortion-free sound even at high output levels. Its robust construction and advanced components make it suitable for demanding car audio installations, providing both durability and superior performance.
  • The first 4" coil XBL² ultra subwoofer on the market
  • Paper cone with diamond dust cap gives this subwoofer years of life
  • Proprietary dual progressive roll spider offers the most linear excursion you can imagine
  • Huge dual Y35 ferrite magnets further add to the making the motor structure strong and linear
  • Each voice coil can take 3,000 watts RMS to let you truly feel the bass
  • Designed for extreme car audio, home audio, and even pro audio applications
  • Hand built in the U.S.A.
We'll send you an email when Adire Audio ADKA18D2 18" Kali Subwoofer DVC 2x2 Ohm is back in stock or available for preorder.
Introducing Adire Audio's Kali Series subwoofer—an ultra-high-excursion powerhouse with groundbreaking 4” coil technology. Following Adire Audio's move to California, they aimed to push the boundaries of XBL^2 motor technology, creating a subwoofer with unmatched precision and strength.
The Kali is equipped with a massive dual stack of 250mm Y35 ferrite magnets, offering 40mm of linear excursion, with inductance rings embedded throughout the FEA-optimized motor structure and magnetic gap for an ultra-strong, ultra-linear motor structure. With a proprietary 10” dual progressive roll spider crafted from a durable phenolic resin-impregnated Nomex poly-cotton blend, the Kali ensures consistent, linear excursion even in high-demand applications.
Built rugged, the Kali features 4 AWG push-pin terminals, a non-pressed kraft pulp hybrid fiber cone, and a multi-layer foam surround, complete with a standard carbon fiber dust cap for enhanced rigidity. CNC-machined gap venting pairs with a 4” 4-layer flat-wound aluminum voice coil to allow the Kali to reach 3,000 watts RMS, maintaining clean, powerful performance for extreme car audio, home audio, and professional audio applications. With power handling up to 3,000+ watts, the Kali delivers intense, eye-rattling low-end with precision and durability, making it the ultimate choice for those who demand linear, powerful bass in any setup.
BrandAdire Audio
ModelADKA18D2
Part Number294-156
UPC753459722145
Nominal Diameter18"
Power Handling (RMS)3000 Watts
Power Handling (MAX)6000 Watts
Sensitivity88.9dB 2.83V/1m
Resonant Frequency (Fs)22.87Hz
DC Resistance (Re)3.72Ω
Mechanical Q (Qms)5.59
Electromagnetic Q (Qes)0.5
Total Q (Qts)0.46
Compliance Equivalent Volume (Vas)7.69ft³
Mechanical Compliance of Suspension (Cms)0.1mm/N
BL Product (BL)22.35T·m
Diaphragm Mass Inc. Airload (Mms)468.06g
Maximum Linear Excursion (Xmax)40mm
Surface Area of Cone (Sd)1217.73cm²
Cone MaterialPaper
Surround MaterialFoam
Overall Outside Diameter18.50"
Baffle Cutout Diameter16.75"
Depth12.25"
# Mounting Holes6
Sealed Volume2.833ft³
Sealed F342.74Hz
Vented Volume9.339ft³
Vented F321.07Hz
