  • AC Infinity CLOUDPLATE T9 PRO 3U Rack Cooling System with Front Exhaust
CLEARANCE AC Infinity CLOUDPLATE T9 PRO 3U Rack Cooling System with Front Exhaust
AC InfinityPart # 305-418
Model: CLOUDPLATE T9 PRO
The Cloudplate T9 Pro 3U rack cooling system utilizes a programmable fan speed controller, enabling it to work for a wide range of rack mount applications. With a noise level as low as 12 dBA, this fan system can be used for environments where low or minimal noise necessary such as home theater, studio, DJ, and audio video racks. A max airflow rating of 300 CFM will provide adequate cooling to server, network, IT and equipment racks requiring high airflow.
  • An intelligent fan system designed for cooling A/V, DJ, server, network, and IT equipment racks
  • This kit protects rack-mount equipment from overheating, performance issues, and shortened lifespans
  • Programmable thermostat controller with automated speed control, alarm warnings, and backup memory
  • Premium anodized aluminum construction with CNC-machined detailing for a professional appearance
AC Infinity CLOUDPLATE T7 2U Rack Cooling System - Exhaust
Price: $139.00Part # 305-406
See all items in Equipment Cooling
We'll send you an email when AC Infinity CLOUDPLATE T9 PRO 3U Rack Cooling System with Front Exhaust is back in stock or available for preorder.
This intelligent cooling fan system is designed to be mounted onto a wide range of 19-inch racks requiring quiet or high airflow cooling. Maintaining an optimal temperature for rack-mount equipment prevents overheating, ensures constant performance, and extends their lifespan. Improper ventilation and cooling is one of the most common reasons for equipment failure in A/V equipment.
The LCD digital controller features a programmable thermostat with automated speed control, alarm warnings, status alerts, and backup memory. This system is housed in a solid aluminum construction that takes up three rack units (3U) of space. Each aluminum frame is anodized with a light-brush finish, then the corners CNC-machined and edges chamfered for a high-end professional appearance. The fans contain dual ball bearings rated at 67,000 hours, a testament to their longevity.
The fans are designed to exhaust hot air and should be positioned near the top of the rack. This complete kit includes the 3U fan unit, corded 6-ft thermal probe, user’s manual, rack mount screws, cage nuts, and corded 6-ft power supply.
Specifications: • Input voltage: 12 VDC • Power supply input: 100 - 240 VAC • Rack mount size: 3U • Design: Exhaust • Total airflow: 60 - 300 CFM • Total noise: 12 - 38 dBA • Cord length: 6 ft. • Dimensions: 19.0" x 5.25" x 2".
BrandAC Infinity
ModelCLOUDPLATE T9 PRO
Part Number305-418
UPC819137020023
Weight5.8
