AC Infinity CLOUDPLATE T7 2U Rack Cooling System - ExhaustThis intelligent cooling fan system is designed to be mounted onto a wide range of 19-inch racks requiring quiet or high airflow cooling. Maintaining an optimal temperature for rack-mount equipment prevents overheating, ensures constant performance, and extends their lifespan. Improper ventilation and cooling is one of the most common reasons for equipment failure in A/V equipment.
The LCD digital controller features a programmable thermostat with automated speed control, alarm warnings, status alerts, and backup memory. This system is housed in a solid aluminum construction that takes up two rack units (2U) of space. Each aluminum frame is anodized with a light-brush finish, then the corners CNC-machined and edges chamfered for a high-end professional appearance. The fans contain dual ball bearings rated at 67,000 hours, a testament to their longevity.
The fans are designed to exhaust hot air and should be positioned near the top of the rack. This complete kit includes the 2U fan unit, corded 6-ft thermal probe, user’s manual, rack mount screws, cage nuts, and corded 6-ft power supply.
Specifications: • Input voltage: 12 VDC • Wall adapter input: 100 - 240 VAC • Rack mount size: 2U • Design: Exhaust • Total airflow: 50 - 220 CFM • Total noise: 10 - 36 dBA • Cord length: 6 ft. • Dimensions: 19.0" x 3.5" x 1.5".
