  • 8-Outlet AC Surge Protection 3300 Joules Metal Power Strip Switched Outlets 6 ft Cord ETL Black
CLEARANCE 8-Outlet AC Surge Protection 3300 Joules Metal Power Strip Switched Outlets 6 ft Cord ETL Black
Parts ExpressPart # 125-617
Individually control the AC electricity for up to eight devices with this switched commercial grade 8-outlet power strip with surge protection.
  • Save energy with eight individual switched outlets
  • 3300 joules surge strip helps protect plugged in devices
  • Heavy duty 6 ft. 14 AWG AC cord for high current needs
  • Lit switches identify which outlets are on
  • Black durable metal body for everyday work shops
CLEARANCE $25.89
412 In Stock
We'll send you an email when 8-Outlet AC Surge Protection 3300 Joules Metal Power Strip Switched Outlets 6 ft Cord ETL Black is back in stock or available for preorder.
Order in the next 4 hr 12 min to ship today. Details
Save Energy
Save electricity by individually controlling the AC power for up to eight devices with this commercial grade 8-outlet AC power strip. Each AC outlet features its own lighted switch, giving you the ability to turn devices on or off as needed—what a great way to reduce energy waste! The power stirp still has a lighted master power/breaker switch that gives you control over the entire unit, plus trips to off during an over current condition. For your safety, this product is ETL certified, assuring you that performance meets high safety standards.
Built to Last and Protect
Designed with durability and device protection in mind, this power strip boasts a hefty 14/3 AWG 6 ft. SJT AC cord and a robust metal-enclosed body, making it more robust than typical plastic alternatives. The sides are covered with ABS plastic, adding an extra layer of protection. Plus, with 3300 Joules of surge protection, you can feel confident that your devices are safeguarded against potential damage.
Versatile Mounting Options
It’s size and mounting options make installation a breeze! Its dimensions of 20-1/8” W x 2" H x 3-1/8" D make it spacious enough for your devices without taking up too much room. The strip comes with four screws to mount to a wall or workbench with two rear plus sign, or four standard holes. Using the plus sign holes it’ll even mount to the outside of a 19” rack (rack screws sold separately).
Built-In Cable Guides
After mounting, plug in your devices and route the cables of each device through one of the built-in plastic wire guides on each side of the outlet strip. This keeps the cords from spreading out on your desk or work area. Use split loom or split braided sleeving (sold separately) for a neat looking finish. The 8-outlet spacing prevents most AC adapters from covering empty outlets.
Space Saving Right Angle Plug
The outlet strip’s right angle AC plug lets you push furniture close to the wall, and the plugs tilted 45° to prevent covering up the bottom outlet for two strip applications.
Take control of your power usage while ensuring the safety of your devices—this power strip is a fantastic investment for every home or workspace. Embrace efficiency and peace of mind with this reliable solution!
Specifications: • Electrical rating: 125V AC 15A 1,875W, 60 HZ• Number or AC outlets: 8 • Surge protection: 3300 Joules • Clamping surge voltage: 700V 6kV/3kA • Max spike current: 6,500KA • Max surge voltage 6,500KA • Response time: Less than 25 ns. • AC cord: JST 14/3 AWG 6 ft. • Dimensions: 20-1/8” W x 2" H x 3-1/8" D (512 x 51 x 80 mm) • Mounting hole horizontal spacing: 18-15/16” (48 mm) to center.
Part Number125-617
UPC848864079257
Weight0.97
ColorBlack
Cord Length6'
Number of Outlets8
