  • Commercial Grade 5 Outlet Surge Power Strip with Two USB Charging Ports 6 ft. Cord Circuit Breaker/Switch
CLEARANCE Commercial Grade 5 Outlet Surge Power Strip with Two USB Charging Ports 6 ft. Cord Circuit Breaker/Switch
Parts ExpressPart # 125-423
Provide power to all the devices in your system with this 5-outlet surge protected outlet strip with dual USB-A 5V 3.4A charging ports. The outlets are arranged so the cord flows away from the power strip instead of along the power strip, and 450 joules of power surge protection keep your system safe.
  • Sturdy aluminum housing
  • Dual USB-A 5V 3.4A charging ports
  • 15 amp circuit breaker/switch to prevent overcurrent
  • 450 joules of surge protection to keep your investments safe
  • Illuminating switch for power on status
We'll send you an email when Commercial Grade 5 Outlet Surge Power Strip with Two USB Charging Ports 6 ft. Cord Circuit Breaker/Switch is back in stock or available for preorder.
If your workbench or rack is becoming overloaded with small power strips or you're out of outlets, this power strip could is the solution. It provides 5 outlets with the main power switch that also functions as a 15 amp circuit breaker. The outlets are arranged so the cord flows away from the power strip instead of along the power strip. This surge protector has included slide-in T-shaped wall brackets for easy wall or rack mounting. The dual USB-A charging ports provide 3.4 amps when using only 1 socket, or shares the 3.4 amp when using both sockets. An integrated 15A lighted circuit breaker switch allows you to simply turn off and back on to reset. The included mounting hardware provides an easy way to attach the outlet strip to your rack or bench for easy access. The power cord is 6 feet long, SJT rated, 14 AWG, and 3 conductors. Outlets are 1" center to center. 450 joules of power surge protection. Dual USB-A 5V 3.4A charging ports. Overall dimensions: 11-1/2" L x 1-3/4" W x 1-1/2" D. ETL certified, and conforms to UL 1363 and 1449 standards.
Part Number125-423
UPC848864065359
Weight1.55
ColorSilver
Cord Length6'
Number of Outlets5
