  • 6-Outlets Extender Rotating Power Strip Surge Protector 6 ft Cord and 3 USB-A/1 USB-C PD Ports Black
CLEARANCE 6-Outlets Extender Rotating Power Strip Surge Protector 6 ft Cord and 3 USB-A/1 USB-C PD Ports Black
Parts ExpressPart # 125-602
Six outlet power/surge strip with rotating sockets frees all six outlets to be used even with large AC adapters. It also has PD USB-A and C ports for fast charging iPhone, Android, and other smartphones with quick charging options.
  • Rotating sockets prevents loss of nearby outlets
  • Right angle AC plug with 45° turn prevents covering up the other wall AC outlet
  • 1020 joules surge protection circuitry helps prevent damage to plugged in devices
  • Two PD quick charge ports for USB devices and smartphones that accept the technology
  • Green light for protection status
  • Two USB-A ports for standard 5 VDC charging
  • Power/breaker switch for overloads and power saving when not in use
CLEARANCE $15.45
Save $19.53 (56%)
276 In Stock
We'll send you an email when 6-Outlets Extender Rotating Power Strip Surge Protector 6 ft Cord and 3 USB-A/1 USB-C PD Ports Black is back in stock or available for preorder.
Never Cover Up a Needed Outlet
The six-outlet innovative design enables you to maximize space and efficiency by accommodating large AC adapters without blocking neighboring outlets. No more juggling devices or searching for a spare socket—this power strip ensures that all six outlets can be utilized at the same time.
Includes Two USB PD Charging Ports
In addition to traditional outlets, the power strip features Power Delivery (PD) USB-A and USB-C ports. These ports are designed for fast charging, making it quick and easy to power up your iPhone, Android, and other smartphones equipped with quick charging options. You can say goodbye to long wait times and hello to convenience!
Whether you’re working from home, powering multiple devices, or simply ensuring your household gadgets stay charged, this product offers both functionality and peace of mind. Get it now and enjoy the freedom of having all your devices fully powered and ready to go whenever you need them!
Specifications: • Maximum surge dissipation: 1020 joules • Electrical rating: 125V AC 15A 1,875W • PD charging: 30W • Standard USB: 5 VDC 4.8A shared • Clamping surge voltage: 700V 6kV/3kA • Max spike current: 6,500KA • Max surge voltage 6,500KA • Response time: Less than 25 ns. • Power cord: JST 6 ft. 14 AWG 3C • Dimensions: 7-5/8" W x 4-1/2" D x 1-1/2" H • T-shaped mounting screw hole spacing: 4-7/8" to center (screws sold separately).
Part Number125-602
UPC848864077116
Weight1.46
ColorBlack
Cord Length6'
Number of Outlets6
