  • 5-In-1 Stainless Steel Wire Stripper 22-10 AWG with Wire Cutter, Spring Back, and Padded Handles
CLEARANCE 5-In-1 Stainless Steel Wire Stripper 22-10 AWG with Wire Cutter, Spring Back, and Padded Handles
Parts ExpressPart # 360-633
1 Question, 1 Answer or
The 5-in-1 tool features a wire stripper, wire cutter, wire looping and bending action, and pliers. The stainless steel body delivers long lasting performance in damp climates.
  • Soft cushioned handles help prevent grip fatigue
  • Stainless steal body for long lasting performance in damp climates
  • Spring coil release action for convenience
  • Locking latch keeps the tool shut while not in use
CLEARANCE $8.99
MSRP: $24.99
Save $16.00 (64%)
7 In Stock
We'll send you an email when 5-In-1 Stainless Steel Wire Stripper 22-10 AWG with Wire Cutter, Spring Back, and Padded Handles is back in stock or available for preorder.
Add this 5-in-1 tool to your tool box, tool belt or tackle box. It's one tool that keeps cutting and stripping wires even in wet environments. No need to worry about this tool getting wet. It has a stainless steel body that doesn't rust. This makes it perfect for wiring jobs on boats, jet skis and other marine applications.
Not only does this multipurpose tool strip wires 22-10 AWG (0.6-2.6 mm), it also has pliers for pulling wires out of tight spaces, holes for looping and bending wires, and one hole that cuts solid steel wire. The cushion handles add grip and help make this tools everyday use more comfortable.
Part Number360-633
UPC848864070827
Weight0.29
