  • 3.5mm Male to Female Slim-Plug Shielded Extension Cable 50 ft.
CLEARANCE 3.5mm Male to Female Slim-Plug Shielded Extension Cable 50 ft.
Parts ExpressPart # 240-063
These slim plug extension cables follow the same physically smaller design trend as your equipment, making sure that they're visually unobtrusive and fit better with more protective cases than traditional 3.5 mm ever have!
  • No need to remove protective cover to connect your audio device
  • Shielded for maximum external noise rejection
  • Connect to home or portable music devices
CLEARANCE $1.84
Save $14.15 (88%)
341 In Stock
We'll send you an email when 3.5mm Male to Female Slim-Plug Shielded Extension Cable 50 ft. is back in stock or available for preorder.
With audio electronics getting smaller all the time, the 3.5 mm stereo cable is becoming a much more common way to connect audio sources such as computers, cell phones, and MP3 players to amplified speakers, home stereo equipment, or portable DJ systems. Sometimes, an integrated 3.5 mm cable just isn't... quite... long enough. For those instances, this extension cable will come in handy.
This slim plug 3.5 mm stereo cable fits more than just the visual aesthetic of today's electronics. The 6.5 mm diameter plug with integrated strain relief works with many protective cases that you'd have to remove for use with a traditionally-sized plug, easing frustration and saving wear and tear. Designed with 100% shield, this cable resists external interference and noise that kill your musical experience.
Part Number240-063
UPC844632004001
Weight0.6
Cable Length50feet
Cable Type3.5 mm Male to Female
Jacket ColorBlack
