  • 3 Ohm 10W Resistor Wire Wound 5% Tolerance
Parts ExpressPart # 016-3
3 ohm 10 watt wirewound resistor with 5% tolerance. Sold individually.
  • Exceptionally small, sturdy, and reliable
  • Ceramic flame retardant package
  • Sealed with a special quartz mixed sand cement
  • Excellent moisture resistance
  • High temperature stability
  • 5% tolerance
  • Temperature Range: -55°C ~ +155°C
Your Price: $1.30
MSRP: $1.99
Save $0.69 (35%)
638 In Stock
We'll send you an email when 3 Ohm 10W Resistor Wire Wound 5% Tolerance is back in stock or available for preorder.
3 ohm 10 watt wirewound resistor. Through-hole termination with axial leads. 5% tolerance. RoHS compliant. Dimensions (mm): Case: 49 L x 10 W x 9 H (±1); Lead length: 35 (±5). Sold individually.
Part Number016-3
UPC844632033391
Weight0.0013
CompositionWirewound
Power Rating10W
Resistance
Tolerance5%
