  • 24V 1A DC AC Adapter with 2.1 x 5.5mm Tip Positive Plug
Parts ExpressPart # 120-241
This high quality AC adaptor is useful for many applications. Always select an adaptor with the same voltage. Specifications: • Regulated power output: 24 VDC, 1000 mA • Input requirements: 100~240 VAC, 50/60 Hz • Plug tip size: 2.1 x 5.5 mm • Power cord length: 6 feet • UL and FC approved
  • Switching power supply delivers consistent voltage
  • UL Approved for safety
  • Level VI standby efficiency saves electricity when not in use
Your Price: $7.98
Save $6.01 (43%)
92 In Stock
We'll send you an email when 24V 1A DC AC Adapter with 2.1 x 5.5mm Tip Positive Plug is back in stock or available for preorder.
This high quality AC adaptor is useful for many applications. In most applications, you can use an adaptor with a higher capacity. However, always select an adaptor with the same voltage.
Specifications: • Switching power output: 24 V, 1000 mA • Maximum power output: 24W • Input requirements: 100~240 VAC, 50/60 Hz • Current consumption: 1A • Plug tip size: 2.1 x 5.5 x 10 mm • Polarity: Center-positive tip • Power cord length: 5 feet • UL approved.
Part Number120-241
UPC848864068459
Weight0.24
Center/Tip PolarityCenter Positive
Current Capacity1000mA
DC Output Voltage24V
Input Voltage100~240 VAC
Plug Size2.1 x 5.5 mm
