  • 5-Pack DC Coax/Barrel Jack 2.1 x 5.5mm Barrel Power Panel Mount with Protective Cap
CLEARANCE 5-Pack DC Coax/Barrel Jack 2.1 x 5.5mm Barrel Power Panel Mount with Protective Cap
Parts ExpressPart # 090-5040
Add these 2.1 x 5.5mm panel mount coax DC power jacks to your next project. They include a rubber cap to keep dust and moisture out when not in use.
  • Rubber cap keeps dust and moisture out when not in use
  • Easily mounts in a 5/16" hole
  • Economical 5-pack
CLEARANCE $0.89
Save $5.10 (85%)
511 In Stock
We'll send you an email when 5-Pack DC Coax/Barrel Jack 2.1 x 5.5mm Barrel Power Panel Mount with Protective Cap is back in stock or available for preorder.
Easily add a protected 2.1 x 5.5mm jack to your next low voltage project. It easily mounts into panels up to 1/8" thick and requires a small 5/16" hole. Each jack includes a nut to securely mount it and a rubber cap to keep dust and moisture out.
Specifications: • Body dimensions: 0.48" H x 0.4" Dia. at its widest point • Terminal dimensions: 0.09" wide, 0.023" thick, and the longest one is 0.23".
Part Number090-5040
UPC848864063720
Unit of MeasurePackages
DC Power Connector TypeJack
