  • 24 VDC 5A Switching Power Supply with 2.5 x 5.5mm Tip + Plug and Grounded AC Cable
CLEARANCE 24 VDC 5A Switching Power Supply with 2.5 x 5.5mm Tip + Plug and Grounded AC Cable
Parts ExpressPart # 120-155
This regulated 24 VDC 5A power supply is ideal for replacing lost or damaged power supplies from your electronic devices or as a foundation for new projects.
  • Efficient and reliable switching power supply
  • ETL certified for safety
  • 24 VDC regulated 5 Amps for consistent output voltage
  • Standard DC 2.5 mm x 5.5 mm x 9 mm tip + plug
  • Certified level VI standby current
We'll send you an email when 24 VDC 5A Switching Power Supply with 2.5 x 5.5mm Tip + Plug and Grounded AC Cable is back in stock or available for preorder.
Switching power supplies are reliable, compact, and efficient. This regulated 24 volt DC 5A power supply provides ample current to run many popular devices and accepts inputs 100~240 VAC. Use it to replace a lost or damaged power supply for AV equipment, office devices, battery chargers, and other electronic components. Approved/listed by; ETL, CUL, and meets level VI requirements. Detachable 4 ft. grounded AC input cord and 4 ft. DC output cord with 2.5 mm x 5.5 mm x 9 mm, center positive plug.
Part Number120-155
UPC848864079295
Weight1.4
Center/Tip PolarityCenter Positive
Current Capacity5000mA
DC Output Voltage24V
Input Voltage100~240 VAC
Plug Size2.5 x 5.5 mm
