  • 22/2 Shielded Mic/Line Cable with Drain Wire 500 ft.
ConsolidatedPart # 101-654
Popular interconnect cable suits a variety of audio applications. Ideal for balanced/unbalanced line level audio, as well as permanently installed microphone connections under floors, in walls, or in racks.
  • Industry-standard 22 AWG two-conductor wire
  • For balanced or unbalanced audio applications
  • Flame retardant gray PVC jacket, RoHS, VW-1 and UL listed for safety
  • CM/CMG rated -4° to 167° F (-20° to 75°), UL2464 rated -4° to 176° F (-20°to 80° C) for adaptability
  • Annealed stranded tin copper conductors (7/30 per conductor) deliver excellent signal transfer and prevents corrosion
  • 100% aluminum foil coverage with 25% overlap with annealed stranded tin copper (ASTM B-33) drain wire prevents outside interference
  • Small 0.167" nominal O.D. makes it easy to hide or run under tight spaces
Your Price: $119.98
MSRP: $119.99
Save $0.01 (0%)
12 In Stock
We'll send you an email when 22/2 Shielded Mic/Line Cable with Drain Wire 500 ft. is back in stock or available for preorder.
Popular interconnect cable suits a variety of audio applications. Overall foil wrap with 25 % overlap provides effective shielding. Durable, easy-to-pull .010" thick PVC jacket rated 300V facilitates long cable runs. The small 0.167" nominal O.D. makes it ideal for running balanced/unbalanced line level audio and microphone connections under floors, in walls, or in racks.
BrandConsolidated
Part Number101-654
UPC848864069043
Unit of MeasureRolls
Weight8.55
Cable RatingCM
Jacket ColorGray
Wire Gauge22
