22/2 Shielded Mic/Line Cable with Drain Wire 250 ft.
ConsolidatedPart # 101-652
Popular interconnect cable suits a variety of audio applications. Ideal for balanced/unbalanced line level audio, as well as permanently installed microphone connections under floors, in walls, or in racks.
- Industry-standard 22 AWG two-conductor wire
- For balanced or unbalanced audio applications
- Flame retardant gray PVC jacket, RoHS, VW-1 and UL listed for safety
- CM/CMG rated -4° to 167° F (-20° to 75°), UL2464 rated -4° to 176° F (-20°to 80° C) for adaptability
- 100% aluminum foil coverage with 25% overlap with annealed stranded tin copper (ASTM B-33) drain wire prevents outside interference
- Annealed stranded tin copper conductors (7/30 per conductor) deliver excellent signal transfer and prevents corrosion
- Small 0.167" nominal O.D. makes it easy to hide or run under tight spaces
Your Price: $64.98
10 In Stock
We'll send you an email when 22/2 Shielded Mic/Line Cable with Drain Wire 250 ft. is back in stock or available for preorder.
