  • 1/4" to 3/8" Spade Terminal with Dual Set Screws and Carbon Fiber and Brass Shell 2 Pair
Parts ExpressPart # 091-3616
Milled from solid brass, with a 24 karat gold plating for maximum signal transfer, these 1/4" to 3/8" forked spade connectors feature a carbon fiber wrapped shell to provide protection from unintended contact while accepting up to 8 AWG wire.
  • 1/4" to 3/8" spade connector for binding posts and screw terminals
  • Color coded carbon fiber shells
  • Dual set screws for maximum cable retention
  • 24 karat gold plated contact surfaces
Your Price: $30.98
Save $14.01 (31%)
115 In Stock
We'll send you an email when 1/4" to 3/8" Spade Terminal with Dual Set Screws and Carbon Fiber and Brass Shell 2 Pair is back in stock or available for preorder.
These 1/4" to 3/8" forked spade connectors are manufactured with a removable threaded sleeve that's wrapped in real carbon fiber for modern appeal and character. A color-coded ring offers quick polarity identification.
Milled from solid brass and plated with 24 karat gold, to provide a long lifetime of service free of oxidation, each connector features two flat-head screws, beneath the removable sleeve, to create a gas-free connection between your speaker wire and the connector.
1/4" to 3/8" forked spade connectors mate with 5-way binding posts and screw terminals commonly found on audio/visual and automotive auto sound electronics such as amplifiers. Accepts up to 8 AWG wire, and the removable tip is interchangeable with the nine-tined banana plug tip used on these connectors as well as the BFA style banana plug tip used on these connectors.. Sold two pair per package, two with red rings and two with black rings. Dimensions: 2-3/8" L x 1/2" Dia.
Note: When using high-strand cable, tinned leads will provide the greatest retention by the set screws. Clear nylon is placed beneath the two screws to secure them during shipping. Please remove prior to use. The knurled portion of this connector is for connector insertion only, please do not try to use it to remove the carbon fiber sleeve.
Part Number091-3616
UPC848864019215
Weight0.181
Contact PlatingGold
Style / TypeSingle
