  • 1/2" Heat Shrink Tubing 3:1 with Adhesive-Black 4 ft.
ThermosleevePart # 080-994
Model: CBDWT3X1/2BK4
Thermosleeve's CB-DWT 3:1 heat-shrinkable tubing presents a remarkable solution for various electrical applications, and its features position it as a highly beneficial component in the field of cable management and protection. Its adhesive-lined nature, combined with flexibility, allows for a secure and robust sealing mechanism that significantly enhances the integrity of outdoor electrical connections. Rated for -67 to 275° F (-55 to 125° C) continuous operation.
  • Organize and protect wires with one heat shrink tube
  • Adhesive sealant works great for marine applications
  • Split resistant for long lasting performance
  • Wide temperature range for multiple applications
  • Even a hairdryer shrinks the tubing at a temperature 230° F (110°)
  • High 3:1 shrink ratio makes it possible to repair most damaged cable jackets without removing connectors
  • UL certified, Halogen-free, flexible, flame retardant heat-shrinkable tubing for versatility and safety
Your Price: $3.98
MSRP: $5.99
Save $2.01 (34%)
We'll send you an email when 1/2" Heat Shrink Tubing 3:1 with Adhesive-Black 4 ft. is back in stock or available for preorder.
Professional Look and Outdoor Protection
Adhesive heat shrink tubing is a remarkable material that deserves a deeper examination for its versatility and efficiency across various applications. Shrinking to 3x its original size (3:1) allows it to provide a snug, secure fit over a range of outdoor electrical connections, making it an essential tool for anyone working with wiring and connections in moist environments. With a continuous operating temperature rating of -67 to 275° F (-55 to 125° C), this tubing proves itself reliable under demanding outdoor conditions, inspiring confidence in its capacity to protect critical connections.
Audio Technicians Love It
Not only is it primarily used as shrink-fit electrical insulation over splices and terminations, but its utility extends to lightweight wire harness covering, wire marking, wire bundling, component packaging, and even fire-resistant applications. This broad spectrum of uses showcases the tubing's outstanding balance of electrical, physical, and chemical properties, making it an indispensable resource in both professional and DIY settings.
Built to Last
Moreover, the heat shrink tubing offers unique qualities such as split resistance and mechanical toughness, ensuring longevity and durability in various environments. Its ability to resist cold flow means that it holds its shape and protective qualities over time, maintaining a robust defense against potential damage.
Seal It
In light of these attributes, adhesive 3:1 heat shrink tubing is a step above regular tubing. It's name states that it holds wires together better, but it also seals out moisture. This is a powerful ally in outdoor electrical insulation and protection. For those engaged in outdoor electrical work, embracing the use of adhesive heat shrink tubing contributes to safer and more moister resistant bond. Plus, the 3:1 ratio shrinking ability aids you when connecting different diameter cables. Thus, I wholeheartedly encourage you to incorporate adhesive 3:1 heat shrink tubing into your toolkit, as it is sure to add extra protection to your outdoor electrical projects.
Note: All 4-foot lengths of heat shrink tubing is folded for shipping. It may arrive with kinks, but don’t worry. When heat is applied the kinks disappear.
Specifications: • UL Recognized at -67 to 257° F (-55 to 125° C) • UL File No. E-180908 • Shrink temperature: 230° F (110° C) • Radial shrinking rating: ≥ 50 • Tensile Strength (MPa): ≥ 10.4 • Flammability rating: VW-1 • Water Absorption (%): less than 0.4%.
BrandThermosleeve
ModelCBDWT3X1/2BK4
Part Number080-994
UPC848864080215
Weight0.01
Adhesive SealantYes
ColorBlack
Nominal Preshrink I.D.1/2" - 12mm
Shrink Ratio3:1
