Talent DM3PAK DynaMic Ultravoice Cardioid Vocal Microphones 3-Pack with CaseTalent's DynaMic handheld microphone is tuned for a specific frequency response that accentuates your voice, capturing every nuance with crystal clear clarity. The DynaMic's rugged body and hardened mesh steel grill protect the dynamic capsule cartridge from accidental drops—it's built it to withstand a 6 foot drop onto concrete—and the wear that comes from touring.
A weather-resistant capsule, integrated wind screen, and custom tailored output impedance combine to make the DynaMic your microphone of choice for outdoor performances and high SPL events. Not only does the integrated wind screen filter out unwanted gusts of air, it also acts as a pop filter and reduces breathing noise.
The durable power switch (for on-stage control) features positive tactile feedback detents—no more embarrassing, "Is this thing on?" guesses in front of a live audience. High quality, nickel-plated XLR contacts maximize signal transfer and resist corrosion.
Talent's DM3PAK packages three DynaMics together in a ruggedized microphone travel case. The internal protective foam is laser-cut for a precise placement of the microphones, and the three included microphone clips, as well as maximum protection.
Still not convinced? Talent is convinced that once you try a DynaMic, the only thing you'll remember about those "legendary microphones" is the legend. All Talent DynaMic microphones come with a 45-day, money-back, no-questions-asked, satisfaction guarantee. Talent microphone cables sold separately.
DynaMic Specifications: • Capsule type: Dynamic • Frequency response: 80 to 16,000 Hz • Polar pattern: Cardioid, unidirectional • Output impedance: 500 ohms • Sensitivity: -54 dB (0 dB=1V/Pa at 1 kHz) • Dimensions: Body diameter: 1-1/4" tapering down to 7/8" at the base, Grill diameter: 2", Overall length: 6-1/2" • Connector: 3-pin XLR.
Mic Clip Specifications: • Entry diameter: 1-1/16" • Exit diameter: 31/32" • Threads: 5/8"-27 TPI.
