  • miniDSP 2x4 Digital Signal Processor
CLEARANCE miniDSP 2x4 Digital Signal Processor
miniDSPPart # 230-320
Model: miniDSP 2x4
The miniDSP 2x4 is a flexible, pocket size DSP processor with 2 x analog IN and 4 x analog OUT. Combined with plug-in software for programming, you can configure the on board audio processing filters in real time from a PC or Mac computer.
  • Plug and play USB driver and real time software configuration using miniDSP plug-ins
  • Customizable for use as a 2-way electronic crossover, parametric EQ, time delay, and more
  • 48 kHz sampling rate delivers CD/DVD quality audio
  • Can be powered by USB or 5-24 VDC for stand alone and car audio use
  • Nichicon Muse audiophile capacitors for minimal noise and distortion
miniDSP 2x4 HD USB DAC Digital Signal Processor
Price: $389.98Part # 230-324
See all items in Digital Signal Processing
We'll send you an email when miniDSP 2x4 Digital Signal Processor is back in stock or available for preorder.
The miniDSP 2x4 is a pocket size Digital Signal Processor (DSP) with two analog inputs and four analog outputs. Typically connected between your analog source and a multi-channel amplifier, the embedded DSP algorithms allow for a wide range of tuning applications.
Whether its subwoofer tuning, multi-way crossover or even equalization of your stereo system, the 2x4 strength lies in its ease of use and flexibility. Based on a hardware plus software combination, you tune the system from user-friendly software on PC/Mac machine. The configuration from the driverless USB connection is live, real time and a onetime requirement. All settings are automatically stored and reloaded at boot up.
Software plug-in (sold separately): miniDSP 2x4 plug-ins
Thanks to 3rd-party tuning software like Room EQ Wizard and the miniDSP UMIK-1 USB measurement microphone, the miniDSP 2x4 makes audio tuning easy.
Specifications: • Digital signal processor engine: 28/56 bit • Host processor: 48 MHz microcontroller • Sample rate: 48 kHz • ADC/DAC data resolution: 24 bits • Analog audio input/output: Unbalanced RCA • Maximum input level: 0.9Vrms (RevA), 2Vrms (RevB) • Dynamic range ADC/DAC un-weighted: >98 dB • Input impedance: 6 K ohms • Maximum level, unbalanced, <1% THD: 0.9Vrms (2.5Vpp) • Output impedance: 560 ohms • Certification: CE, FCC, ROHS compliant • Power supply: Powered from USB cable, 5-24 VDC input via DC 2.1mm round connector • Current requirement: 5 VCD, 150mA • Dimensions: 1.02" H x 4.21" W x 3.7" D.
BrandminiDSP
ModelminiDSP 2x4
Part Number230-320
UPC848864032887
Weight0.65
