  • Dayton Audio ODEUM Series
NEW: Dayton Audio ODEUM Series
Professional High End Drivers
With decades of driver design and engineering, placing emphasis on technical excellence, product reliability, innovation, and value the Dayton Audio ODEUM series takes the stage with a new line of professional drivers made for any venue. Engineered for the ultimate balance in power, control, and affordability, the versatility of the ODEUM series makes these drivers a great solution to upgrade, replace, or develop a new pro sound system.
Live sound is back in business! With years of experience in raw frame driver development, the engineering team at Dayton Audio aimed to design a line of drivers that would deliver terrific performance in live sound applications while maintaining a reasonable price point. As an industry leader in loudspeaker manufacturing, Dayton Audio's years of research and development have paved the way to rock any venue with the ODEUM series. The complete series of ODEUM drivers features two 18" subwoofers, five neodymium midbass drivers, and two 1" exit compression drivers, and is a great solution to upgrade, replace, or develop a new pro sound system. Engineered for the ultimate balance in power, control, and affordability, the versatility of ODEUM will fill any venue for years to come.
Featuring
  • Two 18" 1200 watt tour grade subwoofers with enough power handling to provide thundering low end that fills your event space
  • Five midbass drivers with powerful neo motors deliver low distortion and high SPL perfect for monitors and line arrays
  • Two 80 watt 1" Ferrite exit compression drivers produce a smooth response with bolt on and screw on configurations and your choice of titanium and polyimide diaphragms
Learn More
Apollo
Subwoofer & Midbass Drivers
The Apollo line of subwoofers and midbass drivers delivers high SPL without sacrificing control by utilizing powerful, lightweight magnets in a well-designed motor assembly. The traditional paper cone and cloth surround on each ODEUM Apollo driver make it easy for the entire speaker to move quickly and efficiently for a tight and focused reproduction of any performance. The Apollo line of subwoofers and midbass drivers delivers high SPL without sacrificing control by utilizing powerful, lightweight magnets in a well-designed motor assembly. The traditional paper cone and cloth surround on each ODEUM Apollo driver make it easy for the entire speaker to move quickly and efficiently for a tight and focused reproduction of any performance.
Apollo Subwoofers
Features
  • Available in neodymium or ferrite
  • 1200 Watts of thundering low end
  • High efficiency to maximize amp power and fill your event space
  • Low distortion design features for clean sound reproduction
  • Under spider and periphery venting provide a cooling path to the inside/outside wound copper voice coil
Shop All Apollo Subwoofers
Apollo 18F
  • Nominal Diameter: 18"
  • Magnet: Ferrite
  • Fs: 36 Hz
  • Xmax: 10.6mm
  • Frequency: 35-1,000 Hz
Buy Now
Apollo 18N
  • Magnet: Neo
  • Fs: 37 Hz
  • Xmax: 9.1mm
Buy Now
Apollo Midbass
Features
  • Solid power handling to meet the demands of your gig
  • High output generated from powerful neodymium motor and paper cone and cloth surround
  • Copper inductance caps for lower distortion for clean, clear sound
  • Under spider and periphery venting to keep the inside/outside wound copper voice coil cool and the show running
Shop All Apollo Midbass Drivers
Apollo 6N
  • Nominal Diameter: 6"
  • Power Handling: 200W
  • Voice Coil: 2"
  • Frequency: 90-8,000 Hz
Buy Now
Apollo 8N
  • Nominal Diameter: 8"
  • Voice Coil: 2"
  • Frequency: 75-5,800 Hz
Buy Now
Apollo 10N
  • Nominal Diameter:  10"
  • Power Handling: 250W
  • Voice Coil: 2.5"
  • Frequency: 60-4,200 Hz
Buy Now
Apollo 12N
  • Nominal Diameter: 12"
  • Power Handing: 400W
  • Voice Coil: 3"
  • Frequency: 40-5,600 Hz
Buy Now
Apollo 15N
  • Nominal Diameter: 15"
  • Power Handing: 500W
  • Voice Coil: 3"
  • Frequency: 45-4,500 Hz
Buy Now
Ryman
Compression Drivers
The ODEUM series also features the Ryman compression driver line. Ferrite 1" exit compression drivers with both screw-on and bolt-on configurations produce 80W of power, which gives any system depth and punch.
The Dayton Audio Ryman compression drivers have a response that match a large number of woofers and midbass drivers due to its high efficiency in the frequency range of human voices and midrange detail of stringed instruments. The impedance curve of the Ryman CD makes it easy to pair up with your favorite woofers without taxing your power amplifiers!
Features
  • 80W 1" exit compression drivers delivering a smooth response from 1-20kHz
  • Clean output at 107dB/2.83V won't need much power to produce room filling highs
  • Ships with titanium diaphragm and a replacement poly diaphragm to install, compare, and customize your output
  • Available in screw-on or bolt-on configurations
Shop All Ryman Compression Drivers
Ryman 1017S
  • Exit Diameter: 1"
  • Power Handling: 80W
  • Frequency: 1,000-20,000 Hz
  • Mounting Style: Screw-on
Buy Now
Ryman 1017B
  • Exit Diameter: 1"
  • Mounting Style: Bolt-on
Buy Now
