  • Crossover Selection Guide
A fully assembled and tested passive crossover exists for almost every speaker application, and this guide will help you find the one that's right for you
Hints and tips:
  • It's important to match the crossover's output impedances with the drivers to be connected. Mismatches (i.e. a 4 ohm tweeter connected to an 8 ohm output) will result in improper crossover frequencies, due to passive filter operation being impedance-dependent.
  • Although higher order crossover slopes (12 dB/octave or 18 dB/octave) tend to be more complex and expensive than lower order slopes (6 dB/octave), their sharper cutoff offers much more protection to higher frequency drivers such as midranges and tweeters.
  • "Cabinet-ready" crossovers are built into a dish or plate, to which connectors are installed and wired. Mount them in appropriately-sized cutouts, connect to the drivers, and they're ready for operation. Click on a part number and find detailed info about dimensions and connector styles.
  • Built-in HP (High Pass) attenuation, or high frequency level control, is featured on some crossovers. It replaces external L-pads often required to reduce the output of extremely efficient tweeters and mid drivers.
Don't see what you need?Email our Technical Support Systems or call them at 1-800-338-0531 for fast, friendly, accurate answers to your questions. Also See Crossover FAQs
