  • Yorkville CA1 Coliseum Series 120W Installation Mixer / Power Amplifier 70V / 4 Ohm
YorkvillePart # 245-959
Model: CA1
Versatile input mixing capabilities make the Yorkville CA1 70V installation amplifier the perfect amp for small churches, boardrooms and conference room PA applications. Unlike most installation amplifiers in this class, the CA1 delivers flexible input and output options for use with many installation jobs.
  • 180 watt 6 channel 70V installation amplifier with 4 ohm compatibility
  • Versatile input mixing capabilities with XLR / TRS balanced combo-jack / attenuated RCA unbalanced inputs
  • Individual volume control, clip & activity LED's per channel
  • User selectable phantom power (available on three channels)
Your Price: $419.00
Save $140.00 (25%)
We'll send you an email when Yorkville CA1 Coliseum Series 120W Installation Mixer / Power Amplifier 70V / 4 Ohm is back in stock or available for preorder.
Order in the next 2 hr 36 min to ship today. Details
The Coliseum CA1 public address amplifier has been designed specifically for installations where a versatile paging system with high quality music playback is required.
Ideal for restaurants, small clubs, offices and retail environments where a simple and reliable system capable of servicing multiple paging zones is required. Multiple inputs for microphone or source material, and voice activated paging from either a microphone or telephone matrix means the CA1 can be used in virtually any application. Selectable phantom power is available on three channels to drive condenser microphones, the type most commonly used on podiums or as a lavaliere (tie clip) microphone
XLR / TRS balanced combo-jack inputs and attenuated RCA unbalanced inputs ensure the CA1 system can interface with any source (CD, Cassette, Satellite Tuner, DVD or video system) your installation may require.
Capable of driving either a 4 ohm speaker load, or four separate 70 volt speaker systems (one ‘system’ per zone), the CA1 system delivers 180 watts (mono). A pre-amp output is available to feed an auxiliary power amplifier or active subwoofer to enhance the system, or to feed video or audio recording equipment
Specifications: • Number of channels: 6 • Inputs: 3 x XLR / TRS Combo-jacks, 2 x unbalanced RCA • Phantom power: 48V • SNR: > 55 dB • Frequency response: 50 - 15,000 Hz • Power @ 4 ohms: 180 watts • Power (70V): 180 watts • THD: < 1% @ 1kHz(dB) • Cooling: Passive • Construction: Steel • Rackmount: Yes • Headphone out: Yes • Record out: Yes - main output • Other features: Zone paging, telephone interface • Dimensions: 12" x 19" x 6".
BrandYorkville
ModelCA1
Part Number245-959
UPC840402011187
Weight28.75
Power Output (RMS @ 70V)101W to 200W
Weight Range20 to 29 lbs.
