  • Yamaha NS-C210 Dual 3-1/8" 2-Way MTM Bass Reflex Center Channel Speaker
YamahaPart # 312-616
Model: NS-C210BL
The Yamaha NS-C210 center channel speaker uses dual 3-1/8" aluminum cone drivers and a 7/8" balanced dome tweeter to produce a wide spectrum of sound. The bass reflex cabinet will amaze you with the amount of low end it produces.
  • 2-way bass reflex design produces clean, full-range sound
  • Dual 3-1/8" aluminum cone woofers for fast response
  • 7/8" balanced dome tweeter
  • Slim profile with solid construction
  • Keyhole brackets make wall mounting easy
Your Price: $129.95
We'll send you an email when Yamaha NS-C210 Dual 3-1/8" 2-Way MTM Bass Reflex Center Channel Speaker is back in stock or available for preorder.
The Yamaha NS-C210 center channel speaker produce a ton of sound from a relatively small cabinet. The dual 3-1/8" aluminum woofers and 7/8" balanced dome tweeter used in this speaker creates exceptionally good bass for its size. The woofers' lightweight construction give the cone high-speed movement and fast response.
The ported bass reflex design will produce more bass then you are used to getting from a center channel speaker. All the grunts and groans from vocals will come alive thanks to the NS-C210. Speaker wire included.
Specifications: • Power handling: 40 watts RMS/120 watts max • Impedance: 6 ohms • Frequency response: 65-45,000 Hz • Sensitivity: 86 dB 2.83V/1m • Dimensions: 13-3/8" W x 4-1/8"" H x 5-3/16" D.
BrandYamaha
ModelNS-C210BL
Part Number312-616
UPC027108931388
Weight5.2
ColorBlack
Configuration2-way MTM
Input Rating6 ohm
Mounting StyleWall Mount
Woofer Diameter3.125"
