  • XTC 6-3/4" Round Large Frame Shallow Foam Baffle Pair
CLEARANCE XTC 6-3/4" Round Large Frame Shallow Foam Baffle Pair
Vertek/XTCPart # 260-787
Model: VXT62
The XTC VXT62 foam baffle protects your speakers from dust, moisture, and other forms of contamination while providing acoustical isolation. Extend your speakers' service life, and make them sound better!
  • Protects speakers from water damage and corrosion
  • Improves audio performance of door and panel mounted speakers
  • Self-isolating and self-damping design minimizes door panel noise
  • Keeps contaminants away from speaker cone and voice coil gap
  • Use with full-range speakers, woofers, midbasses, midranges, and coaxial systems
  • Make your speakers live longer!
  • Made in the USA
We'll send you an email when XTC 6-3/4" Round Large Frame Shallow Foam Baffle Pair is back in stock or available for preorder.
Don't let road dust, trips through the car wash, or precipitation ruin your expensive mobile audio system speakers! XTC VXT62 foam baffles protect your investment from harsh conditions, while at the same time guaranteeing peak acoustical performance.
An XTC VXT Series foam baffle protects easily corroded plated parts and vulnerable voice coil gaps. Creation of a separate chamber for the speaker's rear radiation also tightens bass response, reduces distortion, and minimizes the intrusion of road noise though the speaker's cone. The baffle's flexible, long lasting non-degrading composition does not absorb water.
The XTC foam baffle construction also creates an airtight seal for the speaker but also decouples it to prevent annoying speaker-to-panel resonances. Useful in car doors, rear decks, and other interior panels, as well as sub-enclosures for midrange drivers used in large home or PA speaker systems. For use with 6-1/2" to 6-3/4" speakers. 3" deep. Sold in pairs.
Measured Dimensions:
Opening 5.5"
Back: 5"
Depth: 3"
BrandVertek/XTC
ModelVXT62
Part Number260-787
UPC844632093111
Unit of MeasurePairs
