  • Wireless 5 GHz HDMI Extender Optional Receiver
CLEARANCE Wireless 5 GHz HDMI Extender Optional Receiver
Parts ExpressPart # 184-453
Add this extra receiver to part number 184-452 wireless HDMI extender wireless transmit/receiver set. Extends and extra HDMI display device up to 328 ft. away. The set also has a built-in IR extender for remotely controlling the source at the receiver's location.
  • Simple plug and play, no software needed
  • Extends HDMI signal up to 328 ft. for convenience
  • Compliant with HDCP 1.3
  • Supports LPCM and other uncompressed audio
  • Audio sampling rate up to 48 KHz
  • Includes one IR extender cable that plugs into the receiver and transmitter for controlling the source at the displays location
  • FCC, CE, RoHS certified
We'll send you an email when Wireless 5 GHz HDMI Extender Optional Receiver is back in stock or available for preorder.
This wireless HDMI extender lets you extend HDMI audio/video signal up to 328 ft. via 5 GHz band, with very low latency. It's ideal for point to point signal extension situations that require high quality HDMI video in a location where running cable is difficult or impossible. A built-in inferred extender enables the user to remotely control the source with its original remote at the display's location. This receiver kit includes one short IR cable that enables you to keep the wireless box out of sight. You must use the 3.5 mm cable and owner's manual that came with the 184-452 to sync the receiver to the transmitter. Only four receivers are able to sync with one transmitter.
Note: When adding extra receivers, follow the troubleshooting guide line-by-line. You must use the included 3.5 mm cable. Do not connect power to the transmitter or receiver until all other cables are attached. You must press reset on the transmitter and receiver exactly at the same time when instructed. If any of the four receivers stop receiving, power cycle it. Allow two to three minutes after pairing or power cycling for the picture to appear.
Specifications: • Receiver frequency: 5 GHz • Wireless extension distance without obstruction: 328 ft. (100m) • Power Requirements: 5 VDC @ 1A • Output resolution: Up to 1080p 60 Hz, depending on input resolution • Audio sampling rate: Up to 48 KHz • IR frequency range 20 - 60,000 Hz • Chassis material: Metal • Dimensions: 5.12" W x 3.94" D x 1" H (130 x 100 x 25.5 mm).
Part Number184-453
UPC848864059396
Weight1.25
