  • Wavecor WF182BD03 7" Balanced Drive Paper Cone Mid-Woofer 4 Ohm
CLEARANCE Wavecor WF182BD03 7" Balanced Drive Paper Cone Mid-Woofer 4 Ohm
WavecorPart # 298-1196
Model: WF182BD03
2 Questions, 2 Answers or
The Wavecor WF168BD03 is a 7" paper cone midwoofer that utilizes balanced drive technology and is designed for demanding bass and midrange applications. The WF168BD03 is a very good choices for either 2 or 3-way speaker systems.
  • Vented voice coil former for reduced distortion and compression
  • Balanced Drive motor structure for optimal drive force symmetry resulting in largely reduced 2nd order harmonic distortion
  • Built-in aluminum field-stabilizing ring for reduced high-level distortion
  • Large motor structure for better control and power handling
  • Copper cap on center pole to reduce voice coil inductance and to minimize variations in voice coil inductance as a function of voice coil position
  • New vented chassis for lower air flow speed reducing audible distortion
  • Progressive suspension with specially designed conex spider for long durability under extreme operating conditions
We'll send you an email when Wavecor WF182BD03 7" Balanced Drive Paper Cone Mid-Woofer 4 Ohm is back in stock or available for preorder.
The Wavecor WF168BD03 is a 7" paper cone midwoofer that is designed for demanding bass and midrange applications. This driver is powered by a large magnet structure that ensures good efficiency. The WF168BD03 is a very good choices for 2-way speaker systems or even as midrange in 3-way systems.
The large motor system with 1-1/2" voice coil diameter and large magnet for better control, power handling, and efficiency. The optimized paper cone ensures wide bandwidth and low distortion. Distortion is further reduced by efficient venting of the chassis and voice coil former.
BrandWavecor
ModelWF182BD03
Part Number298-1196
UPC848864054995
Weight5.5
Nominal Diameter7"
Power Handling (RMS)80 Watts
Power Handling (MAX)160 Watts
Frequency Response80 to 2,500Hz
Sensitivity91dB 2.83V/1m
Voice Coil Diameter1.54"
Resonant Frequency (Fs)33.8Hz
DC Resistance (Re)3.3Ω
Voice Coil Inductance (Le)0.088mH
Mechanical Q (Qms)8.2
Electromagnetic Q (Qes)0.26
Total Q (Qts)0.25
Compliance Equivalent Volume (Vas)1.14ft³
Mechanical Compliance of Suspension (Cms)1.33mm/N
BL Product (BL)6.75T·m
Maximum Linear Excursion (Xmax)5.5mm
Surface Area of Cone (Sd)131cm²
Cone MaterialPaper
Voice Coil FormerFiberglass
Overall Outside Diameter7.17"
Baffle Cutout Diameter6.02"
Depth3.3"
# Mounting Holes6
Sealed Volume0.101ft³
Sealed F3114.1Hz
Vented Volume0.225ft³
Vented F370.9Hz
