  • Wavecor WF168WA02 6-1/2" Paper Cone Mid-Woofer 8 Ohm
WavecorPart # 298-1190
Model: WF168WA02
The Wavecor WF168WA02 is a 6-1/2" paper cone midwoofer that is designed for demanding bass and midrange applications. The WF168WA02 is a very good choices for 2-way speaker systems or even as midrange in 3-way systems.
  • Vented voice coil former for reduced distortion and compression
  • Gold plated terminals to prevent oxidation, for long-term reliable connection
  • Built-in aluminum field-stabilizing ring for reduced high-level distortion
  • Large motor structure for better control and power handling
  • Black magnet parts for better heat transfer to increase power handling
  • New vented chassis for lower air flow speed reducing audible distortion
  • Progressive suspension with specially designed conex spider for long durability under extreme operating conditions
Your Price: $81.00
Only 1 In Stock More due on 3/6/2026
We'll send you an email when Wavecor WF168WA02 6-1/2" Paper Cone Mid-Woofer 8 Ohm is back in stock or available for preorder.
Order in the next 3 hr 11 min to ship today. Details
The Wavecor WF168WA02 is a 6-1/2" paper cone midwoofer that is designed for demanding bass and midrange applications. This driver is powered by a large magnet structure that ensures good efficiency. The WF168WA02 is a very good choices for 2-way speaker systems or even as midrange in 3-way systems.
The large motor system with 1-1/4" voice coil diameter and large magnet for better control, power handling, and efficiency. The optimized paper cone ensures wide bandwidth and low distortion. Distortion is further reduced by efficient venting of the chassis and voice coil former.
BrandWavecor
ModelWF168WA02
Part Number298-1190
UPC848864054964
Weight2.65
Nominal Diameter6-1/2"
Power Handling (RMS)60 Watts
Power Handling (MAX)120 Watts
Frequency Response60 to 3,000Hz
Sensitivity89dB 2.83V/1m
Voice Coil Diameter1.26"
Resonant Frequency (Fs)47.5Hz
DC Resistance (Re)6.3Ω
Voice Coil Inductance (Le)0.39mH
Mechanical Q (Qms)7
Electromagnetic Q (Qes)0.46
Total Q (Qts)0.43
Compliance Equivalent Volume (Vas)0.87ft³
Mechanical Compliance of Suspension (Cms)0.9mm/N
BL Product (BL)5.1T·m
Diaphragm Mass Inc. Airload (Mms)11.8g
Surface Area of Cone (Sd)139cm²
Cone MaterialPaper
Voice Coil FormerFiberglass
Overall Outside Diameter6.61"
Baffle Cutout Diameter5.63"
Depth2.87"
Sealed Volume0.4ft³
Sealed F387.5Hz
Vented Volume0.8ft³
Vented F347.8Hz
