Wavecor TW030WA07 30mm Textile Dome Tweeter with Rear Chamber 8 Ohm
The Wavecor TW030WA07 is a 30 mm tweeter that was designed for applications requiring extremely low resonance frequency and distortion. Thanks to the extensive internal venting between three internal cavities, no air inside is trapped. This feature extends the usable frequency range downwards to an extend very rarely found on tweeters.
- Extreme internal venting through pole, voice coil former, and top plate to 3 internal chambers
- Reflection-free rear chamber design with solid reinforcement ribs
- Precision-coated textile diaphragm for improved consistency and high-frequency extension
- Large ferrite magnet for improved efficiency and transient response
- Flexible lead wires for higher power handling and larger excursion
- Gold plated terminals to prevent oxidation and ensure long-term reliable connection
- Copper-clad aluminum voice coil wire offering lower moving mass for improved efficiency and transient response
Your Price: $77.00
We'll send you an email when Wavecor TW030WA07 30mm Textile Dome Tweeter with Rear Chamber 8 Ohm is back in stock or available for preorder.
Estimated back in stock 1/9/2026
