CLEARANCE Wavecor FR055WA02 2-1/4" Neodymium Aluminum Cone Full-Range 8 Ohm
The Wavecor FR055WA02 is a 2" aluminum cone fullrange that is designed for compact multimedia installations. The FR055WA02 is a very good choices for any project requiring fullrange audio in a compact space.
- True full-range design with on-axis output to beyond 20,000 Hz
- Dual neodymium magnet structure for high efficiency and almost ideal magnetically shielding
- Copper cap on center pole to reduce voice coil inductance and to minimize variations in voice coil inductance as a function of voice coil position
- Vented polymer chassis for lower air flow speed reducing audible distortion
- Vented voice coil former for reduced distortion and compression
- Low-loss suspension (high Qm) for better reproduction of details and dynamics
- Conex spider for better durability under extreme conditions
We'll send you an email when Wavecor FR055WA02 2-1/4" Neodymium Aluminum Cone Full-Range 8 Ohm is back in stock or available for preorder.
