  • Wattgate 350 AU evo Clear Gold Plated Audio Grade IEC Power Connector
WattgatePart # 110-466
Model: 350 AU EVO CLEAR/SMOKE
Wattgate's 350 AU evo Audio Grade IEC Power Connector is the answer for those seeking the perfect power performance. If you desire pure loss-less power for your top of the line audio equipment, the 350 AU evo fits the bill.
  • Gold plated audio grade AC power connector
  • Accepts 8 to 14 AWG wire
  • Use cable with a diameter up to 19 mm
  • WattLock terminals for heavy duty wire capture
  • Polycarbonate design with all non-magnetic materials
  • High spring rate brass contacts
  • 2.5 mm hex socket hardware holds individual wires tightly
Your Price: $117.00
MSRP: $175.99
Save $58.99 (34%)
2 In Stock
We'll send you an email when Wattgate 350 AU evo Clear Gold Plated Audio Grade IEC Power Connector is back in stock or available for preorder.
Order in the next 14 hr 59 min to ship today. Details
Create the perfect power connection with the Wattgate 350 AU evo connector. These top of the line connectors are audio grade for several reasons. The three layer plating process starts with oxygen free copper, followed by electroless nickel plating, and finally 24k gold plating for improved conductivity.
The WattLock terminals lock in wire gauges from 8 to 14 so you can be confident that heat or vibrations will not dislodge your connections. This connector accepts cable diameters up to 19 mm. The Cryo treatment Wattgate employs means you get maximum AC transfer for premium sonic benefits to both audio and video equipment.
Construction of the connector body is all polycarbonate and uses all non-magnetic materials to reduce interference. These plugs are rated 125 VAC, 15 amp. Housing dimensions: 2.2" L x 1.5" D. Overall dimensions: 2.97" L x 1.5" D.
BrandWattgate
Model350 AU EVO CLEAR/SMOKE
Part Number110-466
UPC601431104666
Weight0.15
ConfigurationIEC
Current Rating15A
Power Connector TypeCable Mount
